I was so sad when missed out on the E3S biggest deal (40%) on the launch and guess the length last month . Waiting for the next one. The new black E3S also looks great
Hello Amutorch, I bought a E3S at Amutorch.com and it has some issue. In every mode the light shuts down after three seconds. I tested several fully charged batteries and it is always the same result. Can you send me a new driver?
Thanks
Robert
It doesn’t include 20350 battery. If you’d like to get a 20350 battery, could you please place the order without the usd2.00 coupon and I could apply a battery for you, what do you think?
Don’t worry that an E3S will be added into the parcel as long as the order is placed through the link above. No problem to add a 20350 battery. Thanks much for your trust. Have a nice day.
This is one time where I finally managed to snatch a Samsung 40T battery with a flashlight (bare batteries do not ship to my country). I appreciate Amutorch making the 40T available for me (otherwise, I won’t be able to get a 40T at a reasonable price).
Anyway, the “disassembly battery” 40T is a genuine 40T that appears to have some weld spots on the top and bottom.
I did a capacity test with SkyRC MC3000 charger (4.20v down to 2.50v at –0.75A discharge rate, and it got around 3900mAh capacity)
Using YR1035 resistance tester, I measured around 8.7mOhms AC IR, which is much better than the usual Lii-40A 21700 I got here (which have around 13-15mOhms AC IR).
Must be a lot of trouble getting cells. Can’t fathom the workarounds with a battery embargo.
Live in Canada and Canadian airlines don’t permit bare batteries as using commercial flights for freight (passenger safety regulations). FedEx / UPS / DHL doesn’t have such restriction but then is ground shipped. Much more expensive. There are smaller air freight companies that also ship, but again is ground transport from air hub to destination. Wrong airport flight and a long trans-country hike.
