Way too long for me to remember, but I can say that I only used it for a few minutes at a time whitewall hunting, so I don’t think it would have been drained all that much.
Has anyone got a picture of what’s below the driver PCB (as shown below), so we can see how the driver board is attached to the light body?
The image below was taken from post 6. In this post JasonWW states:
“Actually, the battery tube does not contact the driver so that heat is not being drawn away.”
If that’s the case, then it’s no surprise the board is overheating. It’s just a matter of time. I was about to state that in all the teardown pictues I’ve seen on this light, I don’t see any thermal compound, but if there’s no ledge for the driver board to sit on then … that explains why.
I hope I’m mistaken, otherwise this is a case of very poor design.
There’s not much point in having a copper head\body option if the driver board is practically floating on air. Please tell me this isn’t the case……
Every 7135 board I’ve seen in other lights is pressed\soldered against the flashlight body so the heat has somewhere to go.
It is normal for a driver board to be mounted like this. There are components on both sides so it cannot sit flush on a flat shelf. It should not be a problem because the driver board does not generate a lot of heat relatively speaking.
The problem with MF01 mini is that the 7135s are transferring heat directly to the temperature sensor on the other side. Anduril sees a rising temperature and because the algorithm is partially predictive, it immediately takes steps. That is my understanding anyway, I am open to correction.
You are correct in your statement that it is poor design and testing. A single test would have revealed this problem to Astrolux, and almost surely did. They shipped anyway because that it is the Chinese way. They will keep doing it as long as people keep buying their half-baked crap.
Aren’t I able to chip in? You said it was Astrolux that shipped the light even though there was an issue. I was just simply stating that Mateminco is who didn’t do the testing, not Astrolux.
How can I order these? I am very interested in obtaining at least one of them to try and many more once I see how well it works. Please any help on how to get the brass heat sink would be very much appreciated.
My MF01 is still in delivery so I cannot look inside.
If someone with this flashlight would be willing to remove the battery tube and un-screw the two driver PCB screws then the board can be lifted for a quick picture.
If there is a metal ledge below the board then we can engineer our way round this issue. If there is no ledge then the problem is much harder to solve.
We need to know if the designer left a ledge on the inside of the tube.
At the moment you can’t, as no one is manufacturing them.
I posted a question on the Bangood website asking if the manufacturer is including the driver heatsink with new lights (it’s rumoured they are), but no one has answered as of today and the question has been up for a while. Astrolux have a Facebook page. You could try and send them a message and ask the same question. The other option is to find a machine shop and have a batch made….
Thanks but I already know that. I assume most people do.
It does not change anything, the light is half-baked, it says Astrolux on it and most people posting in this thread purchased from Banggood. Therefore the criticism is directed there, not upstream.
Although Astrolux is merely a “brand” it does not resolve them of their responsibilities.
I’m mentioning this because most are emailing banggood and not asking Mateminco, they have an AliExpress store and are very responsive. Banggood often don’t know a lot as to the status of their lights.
All new MT07 lights will come with a brass heatsink for the driver board. He didn’t say if MF01 lights would. I’d order from Mateminco if you want to be sure as Bangood don’t seem to know.
Search for ‘Mateminco Store AliExpress’ and Google will take you there.
It’s not possible to order just the brass heatsink from him (I did ask).
If anyone has an MF01 mini, I’d still be interested to see what’s below the driver board……
But according to the above post they said it is not possible to just get the plate. Let’s hope Bangood can make them available if Mateminco isn’t willing to.
Everyone who bought one of these - whether branded Astrolux or Mateminco - should get the heatsink for free. They made a product with a design flaw that 10 minutes of testing would reveal.
