1) FT03 mini with new OSRAM colored LED options.
2) Banggood will be releasing full copper and brass version of FT03 mini (XHP50.2, SST40, and NM.1)
Full copper!
Having Cu and Br C8 i doubt i’ll go for this monstrr heavy option again.
I’d suggest to make bare alu with copper section of driver/led/switch bulge like in MF03 mini
When will these be available?
Under 3 weeks for preorder?
I’m new to this site. is it too late to order?
(just a white light version)
SWEET! Thank you Freeme
Still available, just go to the first page on this post or shoot Freeme a PM for code
Update on the driver - it uses the T1634, as in the D4v2.
Now here’s the fun part - is Astrolux going to make the source code available, and the build used, as required by the GPLv3 license? Is there going to be a pogo-adapter made available, as it uses a non-standard pad layout, and can’t be flashed via a SOIC clip?
Tested pulling ~6.3A on a VCT6, too.
edit:: this was not a fun driver to get out. Short wires everywhere.
Using the 15H version check, the firmware version reads 2019-09-28 (this is also the same Anduril version date on the Meote FM1 Copper with Anduril)…
Any update on the FT03-Mini with Osram NM1 LED? Will it also use Anduril? And also, any idea what’s the max current consumption for the FT03-Mini Osram version (I suppose it has to use different power than the SST40/XHP50.2 which use higher power)
Yep, got the date - I should have checked before; so it’s version 446. Problem is though, what build target have they applied here? As of that build, the only T1634 hardware was the D4V2; is it a fork of that, or a direct “flash and go”?
What’s required is a copyright notice, a link to the code, and information about which config to use.
How many people are interested in FT03 mini NM.1? I need to provide an estimate for Banggood soon.
I was thinking to mod my Blue Mini but if BG vome up with Titanium/Copper or clear alu/copper model i’d be totally in
Will they together with the NM1 use a regulated driver at 4.5A ? A direct driver will be no good for this led.
I'm interested in knowing what a NM.1 is, then maybe. I'll do some search'n... Never heard of it
No luck search'n on BLF
What djozz said...
I can see Astrolux FT03S has got some bad reviews. Has Astrolux improved their build quality with the FT03 mini?
Bad review FT03S SBT90.2 hype train. Is the Astrolux FT03S worth triple price than FT03? - YouTube
Sorry, I ain't got time for a 32 min vid to get a simple answer... Yikes!
I think he means cslnm1.tg - white flat 1.
Interested, SST-40 (5000K) or NM.1(?), depending on which one has the best throw and tint (5700K to 4000K).
