Yea, I didn’t doubt you. It’s a good point, so I guess it’s all the same unless there is only a 2 x 21700 made (maybe weird in parallel). Although couldn’t 3 x 21700 have more mah’s than 4 x 18650? Approx 15000mah vs 12000mah (considering amperage of both is similar meaning 4 x 18650 could be 14400 mah but with lower amperage then the 21700 @ 15000mah). I don’t know, maybe that’s not ever true.
I agree. Tail clicky is necessary for carrying clipped to inside pocket. Also deep carry clip is preferable. Not that many lights with these physical characteristics to choose from, then UI and LED offerings limit the choices even more.
Thanks for this input. I’ve looked into that light and the absence of moonlight is a pretty big deal for me. Still, I didn’t know about the excellent thermal regulation and that’s also important to me. I followed your conversation with the owner in another thread last year and it was fascinating. This light is back on my list.
I would like something similar in size to an Astrolux MF02, with a combination of 2 or 3 throw led OSRAM (each one with their special lens) for a 1.5 or 2 km of throw and 3 or 4 xhp50.2 or xhp70.2 for many flood lumens. Powered by 3 or 4 21700, and fan-cooled, of course with Anduril 2 (when released), with lateral button (maybe 2 buttons, but only in lateral), auxiliary leds…
Basically it would be a flashlight that could illuminate near and far, and that could maintain a good level of light without overheating, being of a large size and weight, but not huge.
Now that I have an EDC05C, I am slightly closer to what it is I want (and I feel like this is probably a better idea than what I described before. I just REALLY wish the UI was better on this thing, but it’s not unusable.
I want to have the EDC05C taken up to the ultimate level.
I want this with a better ui (Anduril?) of course. W2.1 main emitter, basically copying whatever Vinh did to make the D3Cvn have crazy throw (374m of throw, 1000 lumens). Surely that could be done in this kind of light since that’s a 16340 light. I want it to be fully-regulated so it’s efficient, buck-boost if possible. And I would stick with the quad E17a emitters for the side.
I think the best solution to get two fully-functional lights (headlamp/lamp and mini-thrower) would be a mechanical switch that switches between the side emitters, and the front emitter. Basically an Anduril lamp/full-flood headlamp, switchable to a Anduril mini-thrower. I actually use mine as a full-flood headlamp and it does great. I would shift the emitters on the side a bit to allow better use of a headband for using it as a headlamp though.
So, efficient, high-cri full-flood headlamp/lamp, plus mini thrower, running Anduril. All in one.
Thanks varbos for that link!
I too would love to see a modern day high-quality re-issue of such a dynamo light.
Besides, after watching the HBO Chernobyl mini-series, perhaps one of us needs to wade through knee-deep water in a pitch black highly radioactive cellar to operate some drain valves … and our favorite EDC LED light’s battery / electronics has been rendered useless?
Just voted for a head torch. Every once in a while I go jogging with a flashlight attached to my head with a head strap. I often use a zoomie, but I find the beam profile of a Convoy S2+, S21A or similar quite useable. Some throw is needed, but nothing excessive. Color rendering is super important, in my opinion.
I would love to see a head torch built with a sunlight spectrum led. Take a look Sunlight spectrum leds @ Guangzhou Juhong Optoelectronics Co., Ltd., for example. I understand these are COB leds with very high Vf and low intensity, but these are minor issues in a head lamp (imho). Wheight doesn't frightens me (my usual setup is nearly 190g already and I find it comfortable), and I think it would be easy to use one of those sunlight spectrum COB leds (maybe with tint to choose from to the consumer's preference), combine it with an efficient boost converter driver with nice software and… voilà! A bestseller head torch.
Optics would need to be carefully chosen for it to deliver the right amount of throw for night jogging or even bicycle riding. Maybe dual emitter with two different reflectors, or daring short focus travel aspheric setup with precollimator.
