New Olight i1R 2 EOS
I used my old lab forceps, about 50 microns tips and about 200 German Marks in 2000. Gift from a former employer. All went smoothly.
Are you referring to the version 2 or version 1? Your Luxeon TX comment refers to V1 because V2 is definitely not a TX and it’s head is assembled differently. If it is V2 you are referring to did you unscrew or pull?
Got you wrong. Referred to the i3E I mentioned.
Anyway, don’t own any of the i1R, just concluded from the pictures it was a TX. Only now noticed I saw pictures of the original i1R.
No longer sure I want one of those :confounded:
I will accept vintage pair of high quality German forceps as consolation for this oversight. :slight_smile:
You’ll get … my gratitude for all the good information :smiley: :+1:
Got the same color as well, very nice output for the size and a great 5$ o light
Got mine today. It didn’t stay green for very long.
Announced for 8/18 and 8/25, the GAW on olightstore.de has started today.
scalpel_ninja, it looks great! :+1:
How did you do that and what did you use, if you would be so kind to share?
Thanks! :slight_smile:
I used Easy Off oven cleaner. I carefully sprayed some into a disposable plastic container. Then I removed the O-ring and used a small paintbrush to apply it, being careful not to get it into the charging port or charge indicator. Let it sit for 10 minutes, then wipe with a damp paper towel. I did the back half first, then the LED end. When finished, I wiped it again with a damp cloth towel. I installed the O-ring and twisted it closed and rinsed it in the sink to get any residual chemical off.
It was a bit splotchy, so I used a Dremel with buffing wheel and polish to finish.
Thanks for the quick reply and the detailed procedure you used! Gives me the confidence I can do it too! It looks really great! Thanks again! :smiley: :+1:
You’re welcome! It did take 2-3 rounds of application and removal to really get the color out of the knurling. Have fun and hope it goes well for you!
I got mine today. Tint is as cold as the mint body color.
Left: nrgwn, 5600K; right: i2RII
Thanks to reddit user Masterironchef for the brute tip. Remove front half, bang from top. I used this hex key + a bit of mouse pad and banged on it a few times and all the bits dropped to the bottom.
The stock LED is approx 1.75mm x 1.75mm
The LED pads look a bit undersized with maybe a total width of ~1.4mm or something but that is less important than the gap which is too small for me to measure accurately.
I guess this puts us in E21A range sizing up a bit or XD16/E17A sizing down a bit. The optic opening is large at ~4mm.
I have an amber XQ-E I could probably put on there but it would be hideous i’m sure.
Thanks for sharing. How did you desolder the LED?
Preheater on bottom, hot air on top.
The saga continues…
E21A fits! but it’s impossibly hard to center!!
If I recall the + side is the side with the tiny resistor and - is the open side. It’s a little crooked but it’s almost centered and it does work (used multi-meter on driver to test), phew.
Trying to “press fit” everything back together proved to be a challenge. I think I warped my original AL ground ring thing and I could never get it to sit flush enough to reliably go into “high” mode.
Had to fashion new ghetto ground ring out of a sealing washer and part of a spring. I left the bent ring that touches the ground on the driver loose under the washer. Now the entire light is like double the weight :person_facepalming:
Ok whatever, it works. Now for the pièce de résistance! Doh there’s a ugly ring around the outermost spill (was that there before, I think so?) - we can overlook that, I have a big shot E21A that i’m gonna be bragging about on BLF and it’s really bright to boot!
but something else isn’t right and I cant put my finger on it :question:
::Take spectral reading of mystery E21A acquired from friend:: 5400K and 75 CRI, DOH!
To be continued….
agree
trashed!
:confounded:
no wonder they looked so pale
a white elephant gift, so to speak
It has reached its final form…
Different 3500K E21A, took 2 tries to center. I guess I shorted it the first time but the final result was probably more centered than any of my previous attempts so that’s good. I also soldered that final loose ring that contacts the driver ground to the copper washer on just one side so it’s still raised up a little.
Beam is even better than the other E21A, no more off colored outer ring. Left is Sofirn C01S SST-20 4000K - Right is Olight I1R II E21A 3500K
low (4-5lm) / high (75lm+)
:heart_eyes:
beautiful work
