No one has received the GT94 to compare to the GT4 that I am aware of yet. Mine is in the mail I think though and I will do the technical testing. I generally leave the beauty shots side of the review to VOB as he does a better job then me and I tend to be more focused on technical aspects personally anyways.
My guess is that it will be able to run until LVP without damage just like the GT4 as I expect the same or a bit lower overall power draw from the GT94.
Runtime will depend on what brightness level you run it at and what batteries you use. Basic math, brighter light = more power = shorter runtime lol.
Running either this light or the GT4 at the top of the ramp is going to be your best bet for general performance. It should have no thermal issues that way and runtime will be greatly improved over full turbo and still be plenty bright for almost anything.
Which emitter’s more efficient? XHP70.2 or SBT90.2?
All of my experience w/ the SBT90.2 is that it’s insanely power hungry and generates a whole lot of heat, whereas the XHP70.2 always surprises me at how efficient it is. 3-4 of those is way better than 18 SST20’s.
2,569 meters was mentioned by someone a while ago in this thread. I am visualizing beam performance and beam profile that has more throw and less lumens than a certain very large 18 x XHP35 flashlight, yielding more length and less width of the beam. It is going to be exciting to behold!
Yeah the Astrolux MF01S and D18, all are pretty popular lights here and all have 18 SST20 LEDs in various tints. All claim to generate 10-15k lumens. I have a few of those and they overheat quick.
Yeah, I knew about those, I was the one that redesigned those lights lol
Those are actually some of my most used lights, really good general use lights with a nice turbo to show off with. I use the MT03 or MT09R if I need better high output performance in that class but the MT18 has a better tint. I use one nightly to light the room while watching TV.
I just didn’t see how they would of played into a thread on the GT94.
I was just mentioning them in comparison to 3-4 XHP70.2 lights generating around the same lumens or even more and putting out less heat. But my primary question was really about XHP70.2 vs SBT90.2’s effiencies.
That goes against physics. The more intense the hotspot, the farther it’s going to reach. The less intense it is, the shorter it will throw. Unless you’re talking about how large the hotspot is.
An aspheric has far-reaching, more intense hotspot, but will it be as bright as this GT94 over-all?
Btw, l have the aspheric Deft X, and it’s all hotspot, all 700 lumens of it. It’s rated at 1035kcd that time…this GT94 is 1650kcd at several thousand lumens attained by a large hotspot of course.
The FF5 I ordered made it stateside and passed through customs and hopefully makes it here by or before the weekend. I expect it to be close in size to a DEFT X. I don’t have a DEFT X but I do a K40 and a TN32 and several other similar sized lights. But consider the performance difference. The performance of the DEFT X was incredible and still is really. Using light recycling to increase intensity of hand-binned XPG2s it produced like you said, over 1Mcd, all in a narrow beam with 700 Lumens. But the FF5 is going to have a warm beam with 1.2Mlux and 10,0000L. HIDs don’t have the droop like LED lights so heat sinking is less of a consideration compared to heat insulation or rather compartmentalization of the capsule from the electronics and batteries but they have significant considerations. LEDs can happily strobe at ms times at full brightness all day long. HIDs often take over 10s for the beam to fully mature. It’s also not good to turn HID on and off while the capsule components are phase changing. I’ve also noticed that bugs seem to go crazy when you strike up a HID. I am not certain the reason for this but I have always attributed it to the UV and other short wavelengths produced in addition to the thousands of lumens of light and IR. Also a consideration is bulb life, however I will admit that I’ve had many more LEDs die well before the claimed life but no HIDs even on my cars. But I already know that’s going to be the case because LEDs are usually pushed well beyond specifications.
What a time to be alive. My first thrower was the original DEFT around 12 yrs ago and it was mindblowing at 150k lux and maybe 300 lumens. Thrower lights and even most asperics at the time had 80-100klux. I would go up north and blast that thing at a cabins across a bay and see structures light up light alien tractor beam reaching out from the far side of the lake. I can calculate that far less light than that of moonlight was actually getting there. Probably not much need to worry about people freeking out from a twinkling light hitting their window, but we still would limit the Wow throw demonstrations. With these lights now, like the GT lights or the FF5, different story where moonlight is greatly exceeded at theoretical distances of over a mile.
Keeping a close eye on this and the GT4 threads - I’d like to see comparison beamshots before deciding, hopefully the discount codes will still work! My current ‘big’ light is a Thrunite TN40S, I love multi-emitter lights for the combination of flood and throw. The GT4 out-throws my ‘thrower’ TN40S by some way, so that might be the one unless the GT94 looks better, such as plenty of flood and crazy throw, or longer turbo times.
I have the GT4 coming, and not the GT94. For me they are about equally attractive: the GT94 because of the combination of impressive output and impressive throw, the GT4 because of the even more output and the availability of better tint (I will swap leds for better tint than stock), at the expense of throw.
When the GT4 arrives I will know if I made the right choice.
