No I am not. Why did you ask if it is a gift for a woman?
Donāt feed the troll.
Sorry. I didnāt knowā¦
What I mean, itās a very nice tail-cap switch !
It makes the flashlight very beautiful, like a multicolored star in the sky. Congratulation, you have excellent taste !
B cracked and D splash are the most exquisite ! Good job Hank !
You are so right. I forgot myself and thought this was a troll-free forum. Thanks for the wakeup call.
That grey camo though :+1:
Grey camo looks great.
There is a new emitter option - LH351D 90CRI 5000K!
Customized at Emisar/Noctigon, or customized by you? It looks fantastic.
Thanks!
It was a collaboration of an idea I had for the design, realized by a British machinist, Richard Hipwell and then I installed the trits.
How could it compare to the XPL HI V3 3A in regards to brightness and quality of tint, heat etc?
Better CRI obviously, anything else? I donāt have a light with that emitter
Cool. It looks exceptionally nice.
Thank you.
Is it glued? I thought you couldnāt take apart the tailcap like the fw3a.
I made a tool with exact fit and had to apply some force. It was either very tight or had a tiny amount of transparent glue (couldnāt see anything).
My KR4 was not glued but was torqued very tight. It needed a spammer tool to open without damaging the brass retaining ring.
Can anyone comment on the finish of the KR4 Ti vs the D4V2 Ti? I was hoping for something smooth. I found the grip and machining far too abrasive on the titanium D4V2.
The abrasivness will go with use . I did a photo session with mine on strong linen and it did diminished only by moving it around .
lightdecay:Grey camo looks great.
Fairly close or equal in output to XP-L HI, hotter than XP-L HI but cooler than 219C or SST-20, floodier than XP-L HI (pretty close to XP-L HD in beam profile with less tint shift), tint varies wildly depending on batch/bin. If Hank finally got some I would wager the tint is at least decent.
De-doming one would be interesting. Probably need to disassemble the head to get a flat cut.
