A code for the FT03 Mini XHP50.2 would be greatly appreciated as no codes appear to work from page 1 ?
Thanks
I too would love a code for the FT03 Mini XHP50.2
The NM.1 has popped up on BG. Not available yet.
Full copper still happening? Interested!
Ok, NM1 = W1. Put me down for 1 as interested!
Note the more simple driver. Not a problem, just mentioning.
That was my thought exactly!
Interested
Interested. Could I get the coupon?
Interested. Are there any other lights with the nm1 I could look at to get an idea of what its about?
There is the Wainlight C8+ with Osram NM1 LED, this is very similar to other C8 flashlights, but produces a more focused (more throwy) beam, but less total light output.
left:Convoy C8+ with XPL-Hi LED
right: Wainlight C8+ with Osram NM1 LED
Osram NM1 LED has a very tiny light emitting portion (the yellow square)
left: Convoy C8+ with XPL-Hi
Osram NM1 lights up a smaller area but more intense (throws farther).
I suspect the FT03-Mini with Osram NM1 will have similar throw (or a bit better) as the Wainlight C8+ with Osram NM1, but with better user interface.
Also the Osram NM1 LED on the Wainlight C8+ only uses up to 2.8 Amps max power, not yet maximizing the Osram's potential. Hopefully the FT03-Mini will better optimize the power (maybe like 4.5 Amps of power applied to the Osram LED), and also have a well-focused reflector.
def interested in a nm.1
interested blue one
Colored mini just became available on BG
Group buy is ALIVE now.
@freeme
Can you confirm what djozz asked before?
Ordered a blue one.
Regulated driver at max 4.8A. Lights will undergo 24hrs test before shipping.
Ordered a green on green
