The emitters XHP50.2 and XHP70.2 have their own consumer. Who does not like them there are many lanterns with a different emitter.
That’s true. I only don’t like XHP50.2 and 70.2 but i like XHP50 and 70 cause they don’t have yellow goo around emitter. In fact i have XHP70 4500K 90CRI installed in M21C. Just beautifull.
Chatika vas Paus:Finally black S21A! I’ve waited a long time for this. Can you measure the inner diameter of the battery tube? I am also interested in the thickness of the walls.
The same as in S21A, S12…
It means? There is no information in the descriptions. I am asking because I remember that the first batch of S21A had too narrow tubes and did not fit all 21700 cells.
Please add throw distance meters / cd info for the lights in your store, else it’s impossible to judge what to buy. Good choice to add usb charging for the new lights.
All of my 21700 Convoy's are using Molicel P42 and Samsung 40T without problems and since there is enough room there could used even bigger cells
BLF-L:I’m wondering who’s first … :sunglasses:
That would be me LOOOOL
LOL
I think I’ll wait for the new version of M3 with USB-C charging and Ramping UI . Then I’ll make a decision to buy S21B or the new M3. or both of them ?
I'll get them both
But i am waiting for grey version. My OCD doesn’t allow me to buy black Convoy
Black lights matter.
[quote=Lightbringer]
LOOOL
No
Yokiamy:Eagerly waiting for the 4040 gaskets and the 22mm 8A driver to put it together with a CULPM1.TG in a L21a
Same here, that’s what I’m waiting for. I’m also getting a few of the Osram red driver.
Currently using the 8*7135 on the red and it starts out at 230 lumens, drops to 60% within 15 minutes and runs for a further 60min. Since the forward voltage is 2.5v it should run much better with this new driver.
That makes three of us!
I hope Convoy will make Anduril an option for the new and updated flashlights. Also usb-c charger for as many as possible. Most will then probably chose Anduril.
What is the difference in lumen and throw between:
Gray Convoy S2+ with samsung LH351D ,Ra>90,DTP copper board ,ar-coated glass lens
https://www.aliexpress.com/item/1005001388842348.html?spm=2114.12010615.8148356.4.312d32f8mZ8s2U
and
Gray convoy S2+ with luminus sst40 ,copper DTP board and ar-coated inside, Temperature protection management, up to 1800lm
https://www.aliexpress.com/item/33009862476.html?spm=2114.12010612.8148356.46.70216d6cD0YTrZ
The maximum output for the LH351D version probably will be a bit less than the Wukkos FC11 (FET driver), rated as 1300lm, but not very different. SST40 gets about 1600lm. Let’s say the LH351D output should be about 75% of the SST40 version output.
Edit: precise lumen measurements would require a well calibrated integrating sphere.
i have samples ,i will assemble one L21A with 8A driver and CULPM1.TG at next week ,and test the data
YES YES YES, i cant wait to see this.
It’s actually nice that Convoy use their own simple UI, not many of my customers like Anduril and very difficult to sell.
Anduril v2 is another story, once it’s out of its testing phase
08CivicSi: Simon Mao: Coyote2710:hello, best driver for osram 1mm red (CSLNM1.23) around 1.5-2A using single 18650? continuous use on C8+.
i’m making a driver sample for red LED
30–100 two modesdo you know when it will be available for sale?
i will get a driver sample with one 100% mode for red LED in 3days
I would love the 1 mode 100% if you make it available for sale
BLF-L: Simon Mao:3X21A (3*21700 and 3*SST40) is in production now ,it has Type-c charging port
3X21A !!
This is really a good time of the year , Simon is releasing several new Convoy flashlights … exciting.
I’m not sure my wallet is gonna like to hear this news though
Dou you have any picture to tease us? or is it still super secret?I forgot to take a photo last time, the samples are now at the manufacturer. But production has already begun. Its appearance is similar to 4X18A, with corresponding changes.
A 1/4”–20 thread would be a good addition to these lights for tripod mounting (like in the Q8).
The inner diameter is now 22mm
the thickness of the walls is 2.3mm
Simon Mao:i add a link here
S21BBut what about the XHP50.2 emitter version?
i have few 3V XHP50.2 LED in stock ,
I can also install XHP50.2 as you require.
It’s just that I personally don’t like the uneven light spot of XHP50.2.
id30209: Chatika vas Paus:Finally black S21A! I’ve waited a long time for this. Can you measure the inner diameter of the battery tube? I am also interested in the thickness of the walls.
