【convoy】H4 and B35AM options are updated
I think there is no problem at all to increase the current to 3A. The mode of my driver sample is 30–100, but visually the brightness difference between the two modes is very small. I consider only providing one mode 100% or two modes 10–100. I don’t know about hunting. I would like to know if 10% mode is useful for hunting. Or is a 100% mode sufficient for hunting?
Just hurry up with grey so i can add this to the cart :)
Personally, I would favor following forward clicky setting for a red/green light thrower.
Hold 2s from OFF: 0.01% = Firefly mode
Tap #1: 20% = Low
Tap #2: 100% = High (should ideally be stable in output, using a constant current driver)
No strobe, no SOS, no beacon
4x quick tapping: Change mode order (Low-High <> High-Low)
I cannot buy it: “Sorry, this item is no longer available!”
You need a reylight driver :slight_smile:
Yes this would be almost perfect.
100% mode is NOT sufficient for hunting. Having a LOW is important.
I wonder if there is a visible difference between 10-20-30% as Simon mentioned.
SOS: I personally find hidden RED Strobe or SOS or beacon, quite useful.
Our car always breaks down in the wrong place and using a RED flashlight blinky instead of the car blinkies preserves the car battery . Of course it could be Hidden but very useful. on the other hand WHITE strobe is annoying.
Wait… what were we talking about again? Existing light like a C8+ or a fictitious maybe-light?
existing C8+
basicaly a C8+ host with a RED or GREEN OSRAM,
L21A would be good candidate too.
Saw this yesterday. Thanks.
Did the seller said anything?
Monochromatic red is useful for hunting, but what about green? I guess it's not for a traffic light, LoL!
For photographers 10 to 100% is too big a step. I prefer the second mode to be at the point at which the light can run without getting excessively hot.
I sold like hundreds of lights to hunters, literarly all of them were single mode. I offer to put modes as buyer wants, they all say “one mode - 100%” and a few that I sold with 12 modes firmware returned for reprogramming sooner or later.
Aha. Ain’t got, so dunno. Dual-switch, I imagine, to be able to use a FC in the tail.
The L2 has a FC tail, no? Damn, I got 2 of ’em and I can’t recall…
gray S21B?
uh ,you can order the black S21A and note “gray body” in the remarks
I hear you, you are right , 12 modes is a major overkill. I think Low is very useful while hunting. but Lux-Perpetua asked for a simple config mode High~~Low and Low~~>High. Maybe a 3rd mode just 100% would be a plus ?
I think the are talking about a single emitter C8, but not a bad idea for a dual emiter with dual switch.
I think the L2 has an FC in the tail.
I think I jumped too fast to the conclusion that we are discussing both RED and Green KP CSLNM1.F1. :confounded:
Actually, having a GREEN LED is very cool, especially for tracking, often it will reveal more details because gives you more shadows than RED.
When you are in middle of greenery, 540 nm will be borderline invisible for wildlife. But something like 660nm RED is completely invisible to them.
I’ve built or directed more than a few hunters or shooters to rifle lights and they all want on/off only. Multi mode is one more variable hunters don’t want.
I like the old UI from early Fenix TK11 and some Eagletacs with a high low interface via head loosen tighten. A 2x2 mode UI can be very simple and flexible and forward switch compatible.
Really wish this would come back to “tactical” lights
Does the S21B use a pill or integrated shelf?
Shelf. I asked
