Sofirn said that a new batch of LTs are coming soon in green, orange, and desert tan. In addition 200pcs will have USB-C output functionality (not sure what colors for these).
You might want to PM the BLF Sofirn rep to see if that’s possible to do. All that was mentioned was that they’re coming soon but didn’t mention price or where they would be sold from.
Considering previous timelines, I cant help but wonder if “Soon” means the same thing in Chinese as it does in English., I guess we will know ‘sometime’ in the future.
I have seen in the latest users photos of Aliexpress that the newest LT1 come without any pads connected. Has anything changed? Maybe now the solder it’s inside?
The newest LT1 uses 0Ω resistors instead of solder blobs, because that allows automated manufacture instead of manual soldering, which helps Sofirn’s quality control.
If you look very closely at the image, you’ll see four tiny resistors, two labelled R_AMC4 and two labelled R_AMC5. Those are the ones. There’s one of each on the WW side, and one of each on the NW side.
The solder pads were left to give people flexibility in changing the maximum brightness of their lanterns. If you desolder the resistors to reduce brightness and increase runtime, but change your mind, you can increase the brightness again by soldering the pads and save yourself messing about putting the resistors back.
Thanks for the explanation. If I understand correctly the pads 4 and 5 are connected with two resistors and the pads 6 and 7 are not. So if I want to unlock all the power I just have to solder the pads 6 and 7 like I did in the old version.
Don’t you think it’s too much overhead to maintain the quantity used by each signators ? Much simpler, Sofirn is giving discount codes regularly openly or through a PM . I was late to the party but i got the same price .
Nothing concrete at this time, but everyone is aware it is a frequently requested feature. DBSAR and Lexel have both needed (and very much deserve) some time off from projects like the lantern, so I would not count on any updates in the immediate feature.
Wow, that’s awesome!!! Can you share any details about the implementation? If not, I hope @Lexel can, I assume this is also his design.
E.g. will they support USB-C PD (quick charging, with multiple output voltage levels), or just a standard 5V/3A output?
Will the same, single type-c connector be used for power input and output (i.e. type-c dual-role-power, DRP)?
Will the charging controller (TP5100) remain the same in this revision, or will it be replaced, maybe with a fully integrated powerbank controller IC?
Can the light and the power output features be used simultaneously?
Just got 2 lights. Using both off grid 4hrs per night on medium. Voltage drops .1v each night. Should get 10-12 nights runtime. Such awesome lights. Have told friends to buy them.
Question……
1. Can a 3/4 second delay be put on start so that when clicking functions it doesnt flash light in face? During 3/4 second delay if second click is inputted it cancels out white flash.
2. Can battery meter be moved to orange button?
3. Can one warm led be replaced with red and 3rd flash during warm tint ramp function setup activates the 1 red led at 1 lumen?
