Are there any R7S LED bulbs worth recommending?
Interesting name. Feit. Fate. Ill fated? :person_facepalming:
I’ve really been out of the hobby for lack of time since early May… Just moved into a new house and as any true lighting snob would, despised most of the bulbs/fixtures currently installed. Really wishing a truly good and affordable bulb becomes available soon. I still have a handful of Great Value bulbs waiting to get emitter swaps with SunLike 3030s. Also have really been desiring a truly good variable CCT (but not RGB) bulb. Ideally a smart bulb (circadian) that has a time/calendar/latitude programming maybe via BT or even one-time flashing via USB…
p. IKEA Ledare, type LED1708R5.
A dimmable GU10 bulb that uses very warm leds at the lowest brightness setting and gets cooler tint at higher setting by gradually mixing in a cooler set of leds and switching off the warm set at the highest setting.
Gave the 600 lumen version of these a try, and it seems to have mad tint shift. The edges of the beam are outright orange on this set of them. I’m also getting more glare than I expected, but it might be just the beam being a bit narrower (36°).
That being said, found a 3000k Luminus 50W equivalent dimmable 90+CRI 40° GU10 claiming 71 lm/w (as opposed to the 80 lm/w that the 600 W Ledare claims) that seems to be pretty good.
Not seeing it online, but the model name in-store was Luminus Elite+ LED.
StarLike (tssss, it is the secret):
Crowdfunding of mass model of SunLike bulb (TRI-R) — Crowdfunding of mass model of SunLike bulb (TRI-R) updated 02.05.2021
StarLike LEDs is near!
I’d be very interested to hear more about these StarLike bulbs. Is this the next evolution of your SunLike bulbs? Still using the Seoul/Toshiba SunLike 3030’s/COBs?
Lidl have some E27 2700k 806Lm bulbs £3.49 for 2 pack. They are advertised as Ra >=97 but they are just an awful yellow hue, not the normal white/orange but more a bright yellow colour.
Livarno Lux branded
OWIM GmbH
HG06289A
IAN 339473_1910
I’d like to make a web app for this list that is a searchable, filterable list and includes spectrum data/charts. Right now I’m using the X-Rite Colormunki Photo, but I’d really like to be able to chart beyond 730nm. The much more expensive Sekonic meters only go to 780nm. The only competing product I’ve found that goes beyond is an aliexpress find for $1550 called the Hopoocolor OHSP350S that covers 350-950nm, or they have an integrating sphere setup with sensors that cover 200-1100nm, model HPCS6500, for the low low price of $7k.
Any options that I’m not aware of that would allow accurate, repeatable capture beyond 350-750nm?
Sekonic C-800 owner here. Even the best LEDs emit practically zero red light out at 780nm where the meter’s chart ends. And a Google search says human vision drops to zero well before that. But the good new is my bill for consultation is only $3500. You saved 50%
Light outside of 350nm-750nm range is practically invisible to humans. For example, 730nm red light is 117x dimmer than 660nm red light for the same output.
Why do you want to do this?
Horticulture maybe?
It looks like the photosynthetic response and far-red horticulture stuff is within the human visible range too.
I just bought some Quasar Science bulbs from their clearance sale. Here are their measurements:
Quasar Science JDR light bulb 2000k 25deg | 2101K | 0.0026 DUV | 96.9 CRI | Blue light relative amplitude 0.06 | 79.7 R9 | 96.1 R12 | 90 Rf | 94 Rg |
Quasar Science JDR light bulb 3000k 25deg | 3061K | 0.0035 DUV | 97.1 CRI | Blue light relative amplitude 0.39 | 84.3 R9 | 84.8 R12 | 95 Rf | 99 Rg |
Quasar Science medium base filament 3000k | 2766K | 0.0003 DUV | 96.8 CRI | Blue light relative amplitude 0.35 | 80.6 R9 | 84.6 R12 | 93 Rf | 99 Rg |
Quasar Science medium base filament 2000k | 2091K | -0.0009 DUV | 96.1 CRI | Blue light relative amplitude 0.13 | 74.2 R9 | 90.8 R12 | 93 Rf | 101 Rg |
The JDR bulbs have positive DUV resulting in a yellowish/greenish tint. However, the lens can easily be twisted off to insert a sheet of Lee Minus Green Filter. A very easy fix. The filament bulbs are pretty much tintless, though I prefer a negative DUV which makes white appear whiter.
The Hopocolor OHSP-350UV has the widest range I’ve ever seen for hand held spectrometers. Can be had for about $2k
Any experience with the brand? Looks good on paper, but I’m a bit cautious - at the very least I wouldn’t want to compromise the validity of my 350-750 data for sake of wider range.
To reply to the others mentioning the lack of visibility of the light outside of that range:
The first thing that sparked my curiosity was my effort to simulate the look and feeling of sunlight throughout a sunrise. The intensity of sunlight’s output in the 700+ range only continues to grow, and I have to imagine that this could in some way contribute to the quality of life improvements vs a white LED that drops off quickly after 680nm. As deep/far red LEDs become more common, being able to test in that range gets more appealing as well.
Also, there are both benefits and dangers as you get into the UV spectrum as well, and I think it’d be valuable to know what these products are emitting, especially for home lighting.
Just my $0.02 USD.
As I understand, you are searching for rogue wavelengths emitted by cheap bulbs. Unless the bulb is based on a UV emitter, you aren’t going to find any. You see, with LED technology, it’s just a single, 460nm (blue) LED emitter, dusted with a chemical cocktail that causes a conversion of blue light to a whole rainbow of other colors. Check out these readings from these 2 LED bulbs, one cool-white, and the other warm-white. The differences are just in how much blue gets converted by the coating.
To convert to anything outside of visible, would only dim the bulb. And home-lighting bulbs already operate at far lower output than the sun. To re-create that ‘feel’, you only need to buy heating lamps. A UV one and an IR one can be added to any room to give you the same warm feeling as the sun. Of course it comes with all the dangers of unseen radiation, as well as a power bill to boot.
Can you measure % of pulsation of these bulbs ?
HERE IS NEW KING!
WELCOME THE NEW KING!
I just finalized last of the MASS models today
With 3030 6v SunLike TRI-R (3-R) from SeoulSemiconductor:
RIRERA 11 36pcs 3030 LEDs
33$ Ø58x130mm 130grams Δ38° E27/26 e14 GU10 gu5.3/mr16 B22
RIRERA 13D 36pcs 3030 LEDs dimmable
40$ Ø76x141.5mm 205grams Δ38° E27/26 e14 B22
With SOL 2835 3.2v SunLike TRI-R (3-R) from Smart Eco Lighting co ltd:
MASS 13D 60pcs SOL 2835 LEDs dimmable
~35$ Ø75.5x151.5(149)mm 231grams Δ41° E27/26 e14 B22
MASS GX53 48pcs SOL 2835 LEDs
~25$ 111 gram
MASS 7C 19w COB SOL
The same photo with 6C
~25$ E27/26 e14 GU10 gu5.3/mr16 B22
Compare of the size 11 and 13D
Futured bedtime bulb lamp with SOL SunLike 2200k 2250k
7w (asian style body with round diffuser) & 5w (special project body with round diffuser)
About discounts for MASS models
It was the reason why I created it
I think maximum discount will be 20-25% (with 6$ international shipping for any order) and will seems like that: 5+pcs = 5% discount; 15+pcs = 10% discount; 30+pcs = 15% discount; 50+pcs = 20% discount; 100+pcs = 25%
Wholesale price will be about 50% (without shipping)
SPECTRUMs:
there is SunLike 6v 3030 smd spectrums:
SunLikePLUS:
StarLike™ (tssss, it is the secret):
I bought the Hopoocolor OHSP-350UV and played around with it for a few days. Compared with my Sekonic C-800-U, the OHSP-350UV looks and feels much more premium, boots up in 2seconds instead of 20seconds, measures many more parameters, nicer screen, much more responsive, and sensor accuracy seems comparable. They both give about the same values measuring the same sources. Only disappointment is that the OHSP-350UV does not measure TM-30. I miss the RG value, which is an important parameter that I pay attention to. Otherwise this is has the widest range I’ve seen for hand held spectrometers. It measures from UV-C all the way to infrared.
I was surprised to find out how extremely high the UV-C value is in my incandescent bathroom heat lamp. at about 12” from the lamp, the UV-C irradiance is 0.275 mw/cm2!!! This is as high or higher than some portable germicidal lamps!
Sars-Cov2 can be deactivated w/ 2-5 mj/cm2, which means about 10-20seconds from this heat lamp!!! According to safety thresholds, at this level of UV-C irradiance, the time of exposure cannot exceed 10-30s! WTF, how the heck can Amazon be selling something this dangerous!!
Two interesting products:
Battery and AC powered RGBWW high CRI smart BULB, flicker free dimming. Yes, all that, supposedly:
https://www.amazon.com/dp/B08F4Z65ZF/
RGBWW portable photography light:
https://www.amazon.com/dp/B07ZVP5JT3/
