Hello everyone… today we will see the Fenix E12 v2.0: small 160 lumen keychain light powered by AA batteries. The product was sent directly by Fenix for review.
Here you can find all the official info of the Fenix E12 v2.0
Packaging and content
The package includes:
- Fenix E12 v2.0
- AA Battery
- Lanyard
- Spare O-ring
- User Manual
- Warranty Card
The Fenix E12 v2.0, for this review, was sent to me with the battery and Belt clip included but without any other accessories.
Main features and official technical specifications
- MATCH CA18 cool white LED
- Portable EDC Flashlight
- Single AA Battery Powered
- Outputs
- High - 160 Lumens/1 Hour/223 Feet
- Med - 30 Lumens/13 Hours/91 Feet
- Low - 5 Lumens/70 Hours/39 Feet
- IP68 Waterproof Rating
- Aluminum A6061-T6 Body
- Two position pocket clip
- Single tail-switch control for one handed operation
- No standby current when turned off
- Ultra-thin optical lens (3mm) coated with AI+UV
Batteries
- Included: One 1.5V AA Alkaline Battery
- Recommended Batteries: AA Ni-MH Battery or AA Alkaline Battery
Size
- Length: 3.06"
- Head Diameter: 0.75"
- Body Diameter: 0.69"
- Weight:0.96 oz (Excluding Battery)
Levels of Output and Runtime
The Fenix E12 v2.0 has 3 normal output levels. The runtimes vary according to the cell used (Ni-MH or Alkaline).
Lumens and Runtime with Ni-MH Battery:
• High: 160 lm declared(misurati 150 lm) – 1
• Mid: 30 lm declared(misurati 30 lm) – 13h
• Low: 5 lm declared(misurati 6 lm) – 70h
The measured data are to be considered peak (taken within 30 seconds of switching on and with the battery fully charged) and all proved to be consistent with the manufacturer's statements.
The body and the materials
The Fenix E12 v2.0 is a small keychain flashlight, powered by primary AA batteries and capable of providing a maximum output of 160 lumens with a maximum shot of 68 meters.
The lowest level of only 5 lumens allows a runtime of 70 hours.
The materials are of high quality, the finishes are accurate, the thicknesses are abundant and the weight is low.
It is comfortable in the hand, it fits well, the switch is easily operated.
The body, the tailcap and part of the head are finely worked with a precise knurling that guarantees excellent grip and good tactile feedback.
The lettering and the anodizing are well done.
The switch is in the tail, rubberized, mechanical and double-stroke. Pressed until the click allows you to turn the torch on or off while partially pressed it manages the variation of the output levels.
The tail is not flat but tailstanding is still possible.
The optical part consists of a transparent lens with anti-reflective treatment, a particular orange peel reflector and a MATCH CA18 cool white LED
with a cool but not excessively cold tint. The bezel is bronze colored.
The belt clip is particularly sturdy and thick, is double-sided and offers excellent grip on clothing.
Water resistance is guaranteed according to the IPX8 standard, therefore submersible torch up to two meters deep.
Following some nightshots ...
Beamshot #1
Beamshot #2
Beamshot #3
Beamshot #4
Beamshot #5
Beamshot #6
Beamshot #7
Beamshot #8
Beamshot #9
Final judgement
The Fenix E12 v2.0 is a small and handy flashlight that can be taken anywhere.
Perfect as an EDC, its power is adequate for all small daily tasks.
Simple to use, the switch is easily detectable and activated.
Aesthetically beautiful, it is made with top quality materials and finely finished. Good anodizing and knurling of the body that offers excellent grip. The bronze-colored bezel is beautiful.
Cool tint tending to Neutral, perfect EDC beam.
I have not found any particular defects in this new product, and I can only recommend it.
Thanks for reading XD
