Convoy L6+ Batt Voltage Differences
7 posts / 0 new
Hank33
Hank33's picture
How come one batt shows 4.1V and the other shows 3.5 V after using a few days/times after both batteries are fully charged in the beginning??
patmurris
patmurris's picture
Last seen: 1 month 4 weeks ago
In a serial configuration cell voltage may drift a bit depending how close their specs are matched, but not that much…
Are your cells the same brand, model and age?
Hank33
Hank33's picture
I'm using the Sofirn ones. Actually I might add that I measured the voltage differences not after using the flashlight but after sitting unused for a couple of weeks. Maybe if I used it more, then the voltages should even out maybe?
SammysHP
SammysHP's picture
Last seen: 4 min 56 sec ago
Charge both and store both separately for a few weeks. See if they have the same voltage. If not, this is another incident of Sofirn self discharge.
jeff51
jeff51's picture
Last seen: 6 days 8 hours ago
Using it more should not make a difference.
They are in series, so they won’t equalise.
Mark the questionable battery.
If you have a charger that can test the cells do that.
Sounds like one of the batteries is not keeping a charge.
After testing, or charging, keep them sitting outside the light and see if the one battery drops voltage.
All the Best,
Jeff
Hank33
Hank33's picture
Okay good tips…will try them all. Yeah I gonna fire up the BT-C3100 and give errr! Evil
mortuus
mortuus's picture
Last seen: 6 hours 52 min ago
are the cells protected? i wouldnt use non protected in such light.
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
