Thanks. We do have mountain lions as well.
What’s the use of red light?
I have couple of 200 lumens headlamps with dual red LEDs. Red LEDs are much lower than the main one.
What is the use of red LEDs?
Preserving night adapted vision when using low output, and also most animals can’t see red light, so it’s a small way to shift ‘power’ into your favor. I.e. you see them, but they may not see you. This is honestly more a camping than hiking thing though imo as you’ll be using white light while on the move.
As much as I love justifying the need for my many flashlights, while outdoors in these situations I actually prefer to use as little light as possible.
A trip to the toilet in the night would be a situation where I’d use a red headlamp and brought the thrower with me just in case. Getting settled into the tent and as a nightlight very low red/amber light doesn’t disturb your eyesight nor your sleep hormones.
I tend to take a small primary flooder and a compact thrower as a backup / auxiliary light.
Flooder can have as little as 100 lm, AAA zoomie with high CRI LED would be fine (you want high cri on the trail as low cri sometimes make distinguishing things under your feet much harder) though I like somewhat larger aspheric flooders for that. If you’re frugal 10 lm is easily enough to see under your feet though nowadays I use much more just because I can.
Thrower is typically larger, I loved my BLF GT Mini with a shorty tube in this task but now Noctigon K1vn SBT90.2 will take its place.
Yes, but just because you have access to 1000lm doesn’t mean you need to use it all the time, basically any quality modern light that isn’t intended for mounting on a firearm will have multiple modes.
I’d be perfectly comfortable going hiking/camping with a light that maxes out at around 200-300lm though, as long as the beam has some punch/focus and isn’t super floody.
All of what he said, plus it attracts less bugs.
The animals see you at night just fine, they are well adapted, that’s their environment after all…
Let me just recommend the two lights I like to take hiking
AAA lights are my lowest weight option.
I like Lumintop Tool. It can meet my needs at camp.
Maximum lumens is 80, but I generally avoid using maximum on any light. The 20 lumen medium is fine to see the trail, and the 3 lumen low is fine to see the toilet paper.
When I need to step out in the dark for a toilet run, I like to use a CR123 size light.
I like Jetbeam RRT-01. It can show me the bear, before he eats me.
Maximum lumens is 350, and again I dont use it, I seldom need more than 150 lumens, and this light can go down dimmer than I can see, so it does every situation, from inside the tent, to checking the perimeter, and anything inbetween.
red light can be used for hiking, I dont like it
if I dont use white light, I especially prefer Green light.
Think about what your goals are, it will help you decide what light to buy.
or
Think about buying the two lights Im recommending, and learn how they work, when and where. So you have a better idea what to buy after that.
bet you cant buy just one
example
two knives, two fire sources, two lights, two spare batteries… 400 grams.
This was the
“just in case I get stuck out there overnight kit”
I took it day hiking up to the ski area recently.
I did not hike in the dark, but would have been comfortable with my lighting choices, had I needed or wanted to hike in the dark, or camp overnight.
Both for spotting large predators or prey, or just to see the trail or camp.
Tells the mountain lions to stop.
“Two is one, one is none.” Go for redundancy.
Around the campsite or even walking, a headlamp is kind of a must. Invest in a warmer high-CRI light for best all-around light. Warm so you can still sleep later, and high-CRI for better recognition of snakes, branches, and such.
Floody light for area-lighting.
Throwy light to see the mountain lions lying in wait up ahead.
“Balanced beam”, “Throwy, but usable spill”, etc., is garbage. Compromise beams that do neither very well. When you need throwy they don’t have enough reach, and when you need floody the hotspot washes out everything else.
You’ll probably want at least an AAA light on a clip or around your neck in case of getting stranded on a trail but needing some light vs walking off a cliff.
Minimum setup? Floody headlamp, throwy handheld, AAA light (plus packed extra cells) on a necklace.
I mean more from an attention /non spooking perspective… you are maybe less interesting with an invisible wavelength flashlight
On many hikes and backpacking trips I’ve carried my two Zebralights (H600Fd III headlamp and a SC600w HI). A buddy and I have often left work on Friday afternoon, driven to the heart of the mountains and hiked for a few hours after dark to wake up in deep in the woods. Lots of fun with these two lights.
The headlamp is rated at up to 870 lumens which doesn’t sound like much these days, but it’s been plenty for my trips through New York’s Adirondack Mountains. These trails are very wooded so it might not work as well with more exposed mountains like out West in mountain lion country. Like it was mentioned before, keeping a lower level and having a very low level are most comfortable in camp. If I need to see exactly what’s making noise in the distance, the SC600w HI is a great way to punch through the darkness and see what’s up on the outskirts of the campsite.
No need to go as expensive as these. A Convoy or Sofirn or most any other 18650 light with a HI led will serve the same function. There are also a good number of good choices among headlamps too these days.
Have fun and stay safe!
I think versatility is key, I prefer a lot of lumens on a moonless night because there are no shadows. On a moon lit night a good throw is enough just to light up something dark or far away. In the tent or just doing business, I prefer somthing sub lumen,
I was told that the thing with mountain lions, cougars or other cats is they like to sneak up on you and to have someone watch your back and sides. Someone recommended one of those cheap headbands that take a tube light and just wear it in addition to your headlamp so it looks like there are a bunch of lights walking with you and you are not alone.
I don’t actually know if they are scared of a tube light, I have never encountered a mountain lion,
Or get a Hurkins Orbit headlamp for a whole ring of light around you!
Ol’ Snagglepuss won’t know what to think.
Well said :+1:
Thanks for replies.
I haven’t been camping for last few years.
That was before I had decent (new LED) flashlights.
Since 2019, I bought quite a few flashlights and headlamps, although all budget ones but way brighter than my old D cell and 9 LED AAA ones.
I have two AAA flashlights.
One is Ultratac A7 and another is Enjoydeal.
The A7 is warmer (high CRI?) light with high, low and strobe mode with brighter center and lots of spill.
The $2 Enjoydeal is bluish light with just on and off mode and more throw than spill. Throws farther than A7.
As for AA, I have two Ultrafire Q5 SK68 clones. I like the size but I don’t have 14500 batteries to see how brighter these can get.
With AA, the AAA ones I mentioned above are brighter so I won’t be carrying these.
Then bunch of single 18650 and two dual 18650 flashlights, all are zoomies except one.
Then I have one cr123 weapon light that can be used as flashlight as I bought bunch of cr123 batteries and don’t use it much.
Those plus few 500 and 200 lumens headlamps so I think I’m covered for now.
We’ll try when I go out in the dark next time and I may hand few unwanted zoomies out to my friends.
My flashlight journey was started when I lost path in the wood with a group of people, without proper illumination devices.
All incand flashlights runs their batteries out and we managed to go back to basecamp with just one $5 AAA LED flashlight bought from dx.com some months earlier.
The flashlight was actually just a keychain that I put on my vehicle key and it helped us in the 5 hours walk down to the basecamp.
Yeh, like I said, even a backup AAA can keep you from walking off a cliff.
A good headlamp and a thrower like the GT Micro for weight savings while hiking. The Micro for longer distant sighting plus the ramping UI is great and I use my Armytek Wizard Pro because I really like the UI. Its main mode 2 at 200lms will go for 8 hours while main mode 1 at 70lms for 18 hours. It throws plenty of light with its defused lens at 70lms for me but these are my preferences and everyone’s will be different. A good hands free light is a must IMO. There are many great headlamps available from almost all flashlight manufactures nowadays. Good luck in your search for the perfect lighting
Well, I used to mountain bike single track with a fenix L1Tv2 on my helmet so you really don’t need as much light as one would think. Remember the eyes adjust to lower light environments.
If I was going to night hike I’d use a floodier headlamp along with a handheld to reach out if needed. Probably would go with something like my armytek wizard pro and either a ZL sc63w, Sofirn c8f LH351d or my malkoff m361w/219. Along with a single AAA pocket/keychain back up. Nothing too bulky or huge but enough to light up a moderate meadow or field. Actually with a head strap you could shave weight and use the ZL as both a handheld and your headlamp. This would work very well…
Generally for back country I’d try to match battery types on my main two lights for interchangeability if needed. The keychain light I would keep AA or AAA for easy sourcing if recharging becomes an issue somehow.
If my life depended on it, I would only trust the Surefire Titan for AAA.
Also anything that RovyVon sells. They’re just costly, not expensive.
Having a Nichia 219C-700 lumens in my necklace, feels very safe.
I have a few of them. Good stuff. Now they have new models.
They got me again. Dayum!!! no willpower.
Cheers.
