Thank you, the idea of some triple 21700’s is encouraging. A Convoy 4X18A or 3X21A flashlight gives a few great LED options like Luminus SBT-90 or triples.
Awesome! There are only few 21700 button top cells on the market, mostly proprietary batteries with a PCB from Imalent, Klarus, Acebeam etc.. These batteries are very expensive, though. So, let's please stick with support for standard 21700 cells that are flat top or even with a recessed top (see "Tesla" batteries sold by Vapcell). Thanks for the great work, Simon!
So that’s the new Convoy’s grey on the S21B ?
A different shade of grey compared to S2+’s.
That looks gorgeous :+1:
Hey, sorry for my lack of knowledge :person_facepalming: , what is W2.1 ? Is it another osram emitter?
Wait for sec, if you look at sbt90.2 market segment which they are already out, there are as following:
Astrolux FTO3S, MF05S
Noctigen K1
Amutorch
Night?..
Etc
They are pretty good but with their own flaw. E.g, MF05 too massive and expensive, but it will perform absolutely. Other also perform accordingly but you will find decent flaw, it depend.
Now,I do see flashlight manufacture doing hard as they could to implement these beast sbt90.2, what I’m talking about here is, what sort of improvement, update, new feature, innovation, to the upcoming Convoy 3x21 sbt90.2? My expectation was: extra capacity and power and that ok. But that will result increase in mass and shape, these also took affect in the decision of consumer. Unless, there is “WOW” factor, that will be different story. So…it is intesting.
Convoy L2 quick question: what diameter is its driver boot? I think I have read in some other thread that it is slightly larger than ∅20mm, is it? It should fit a ∅22mm like this one with a little bit of filing. Now that the L21A uses a ∅22mm driver boot, it would be a good idea to standardize.
I have a 21mm driver in my L2, even though it is 20mm in the description. 21mm fits perfectly, with no gaps left at the edges, so 22mm won’t go in without modification.
Thanks for replying Chatika vas Paus. The driver is sure to fit as I presumed, after all it fits in a ∅17mm board and so there's plenty of leftover board to file:
I still have a question, though. Is the L2 stock equipped with a reverse switch? I would love to see the switch assembly. I have some Omten PBS101C400s, PBS1288Bs and other oddballs at home but just in case.
