Wait for sec, if you look at sbt90.2 market segment which they are already out, there are as following:
Astrolux FTO3S, MF05S
Noctigen K1
Amutorch
Night?..
Etc
They are pretty good but with their own flaw. E.g, MF05 too massive and expensive, but it will perform absolutely. Other also perform accordingly but you will find decent flaw, it depend.
Now,I do see flashlight manufacture doing hard as they could to implement these beast sbt90.2, what I’m talking about here is, what sort of improvement, update, new feature, innovation, to the upcoming Convoy 3x21 sbt90.2? My expectation was: extra capacity and power and that ok. But that will result increase in mass and shape, these also took affect in the decision of consumer. Unless, there is “WOW” factor, that will be different story. So…it is intesting.
Convoy L2 quick question: what diameter is its driver boot? I think I have read in some other thread that it is slightly larger than ∅20mm, is it? It should fit a ∅22mm like this one with a little bit of filing. Now that the L21A uses a ∅22mm driver boot, it would be a good idea to standardize.
I have a 21mm driver in my L2, even though it is 20mm in the description. 21mm fits perfectly, with no gaps left at the edges, so 22mm won’t go in without modification.
Thanks for replying Chatika vas Paus. The driver is sure to fit as I presumed, after all it fits in a ∅17mm board and so there's plenty of leftover board to file:
I still have a question, though. Is the L2 stock equipped with a reverse switch? I would love to see the switch assembly. I have some Omten PBS101C400s, PBS1288Bs and other oddballs at home but just in case.
Well, that's a bit odd. Crapple has quality hardware, and so the only reason for that to happen is the software.
As an oddball fellow myself I care a lot about the software. Freedom is paramount for me, and so I get Android smartphones which as they arrive at home are bootloader unlocked and customized with some rooted AOSP rom. I couldn't care less about any stock device software, generally raping any unwanted stuff on the way and one of these is the camera application which quickly gets replaced with Open Camera…
I’d say it was my bad choice of settings rather than crapy software. I thought guys just want to see a beam size.
The other problem is that i have no interest in photography so much. Seeing my kids what they are doing with their phones makes me wanna go full wired again.
The White Flat above seems to be a CULPM1.TG (4040 2mm²), doesn't it?
Addiction problems maybe?
As a whole I've had to deal with addictions pretty seriously in this lifetime, and now that I can discern between good an evil / right and wrong, it now is a worrying thing for me to see how much people is stuck in a horrible level of unawareness/unconsciousness.
I did look at the new Convoy Z1 zoomable flashlight, and it looks very appealing. The only thing which holds me back from it, that it is not available with high CRI emitter, just with a “standard”, between 65-70 CRI SST40. Could you offer Z1 with LH351D as well? LH351D has a nice, almost round light emitter surface, because of the dome of the emitter as well, so it should definitely worth it. (Not as big output as SST-40, but should handle 5A current without problems.)
