We all waiting beamshots with big interest.
30cm from the wall,
left S21A 351D 5000K 4mode 6000mA driver on 3%
right S21B W2.1 12mode 6000mA driver on 1%
2.5m from the wall
left S21A on 30%
right S21B on 20%
5m from the unfinished bathroom
S21B on 20%
and S21A on 30%
Famous duo :)
Thanks.
Any change for beamshots on field?
S21A with Samsung is custom order I guess?
Is it a high CRI LH351D?
Tint looks good in the LH351D, but green in the WF 2mm². Did you set white balance to auto id30209?
Convoy L2 quick question: what diameter is its driver boot? I think I have read in some other thread that it is slightly larger than ∅20mm, is it? It should fit a ∅22mm like this one with a little bit of filing. Now that the L21A uses a ∅22mm driver boot, it would be a good idea to standardize.
I have a 21mm driver in my L2, even though it is 20mm in the description. 21mm fits perfectly, with no gaps left at the edges, so 22mm won’t go in without modification.
Thanks for replying Chatika vas Paus. The driver is sure to fit as I presumed, after all it fits in a ∅17mm board and so there's plenty of leftover board to file:
I still have a question, though. Is the L2 stock equipped with a reverse switch? I would love to see the switch assembly. I have some Omten PBS101C400s, PBS1288Bs and other oddballs at home but just in case.
Another oddballity.
Yes, hi cri 351D.
Iphone 8 set to cold settings. Actually tint on Samsung isn’t that rosy at all and Osram isn’t that much green.
Phone camera is shait :(
Well, that's a bit odd. Crapple has quality hardware, and so the only reason for that to happen is the software.
As an oddball fellow myself I care a lot about the software. Freedom is paramount for me, and so I get Android smartphones which as they arrive at home are bootloader unlocked and customized with some rooted AOSP rom. I couldn't care less about any stock device software, generally raping any unwanted stuff on the way and one of these is the camera application which quickly gets replaced with Open Camera…
I’d say it was my bad choice of settings rather than crapy software. I thought guys just want to see a beam size.
The other problem is that i have no interest in photography so much. Seeing my kids what they are doing with their phones makes me wanna go full wired again.
Thanks for the beamshots id30209
Are the reflectors the same size between the A and B model? Any lux readings?
They are the same and interchangable. Only difference is OP vs SMO.
No lux readings whatsoever, don’t have any meassuring equipment.
The only way i can tell how good throw is, is to light up building across, certain lady bedroom and see details in it.
Yolo, old school!
The White Flat above seems to be a CULPM1.TG (4040 2mm²), doesn't it?
Addiction problems maybe?
As a whole I've had to deal with addictions pretty seriously in this lifetime, and now that I can discern between good an evil / right and wrong, it now is a worrying thing for me to see how much people is stuck in a horrible level of unawareness/unconsciousness.
Hello Simon,
I did look at the new Convoy Z1 zoomable flashlight, and it looks very appealing. The only thing which holds me back from it, that it is not available with high CRI emitter, just with a “standard”, between 65-70 CRI SST40. Could you offer Z1 with LH351D as well? LH351D has a nice, almost round light emitter surface, because of the dome of the emitter as well, so it should definitely worth it. (Not as big output as SST-40, but should handle 5A current without problems.)
Yes, you are right.
@ Simon
Can you make bigger lighted switch for high output hosts like S21B, M21C etc?
The one in S21A (lighted as on S2+, C8...) is different than on S21B (non lighted).
Also, threads are different on A and B...
i can use adapters to apply 17mm 5A driver
