My best estimate here for throw is 560kcd. A quick and dirty pixel measurement said each of the reflector wells are about 47mm. Center holes about 13mm. I estimate the total frontal area to be a bit higher than a TN31 (65mm ID), but only by about 6%.
Maximum frontal area assuming three full 47mm wells, which I’ll use as an upper limit, would yield approx 750kcd.
If it were a single reflector, it’d be about 86mm ID. That would about 875kcd with a single 90.2.
I got ~525 kcd from a Shocker (triple reflectors, 100 mm diam head) with dedomed XM-L2 U2's, and ~710 kcd with a dedomed XP-L in a 100 mm diam head BOSS1.
~750 or 750+ kcd is realistic to me for a triple 100 mm head diam running SBT90.2's off of 3 40T's, assuming a good, low resistance electrical path.
Fair enough. My gut is around 680 here. But the calcs I was doing were coming out a good bit lower. When we’re dealing with big numbers like these, a +/-10% error is huge.
Ooops, missed the pic. I see couple issues with the battery choices though: Ouch: 2 different kinds of cells used? Flat tops - gotta wonder how good the contact is, hope all 3 cells are contacting for best amps.
Looks like the cells are in tight, so wondering if that's the best minimum width or are the walls of the tube thicker than a Q8. Awesome wall of light in the beamshots - Yes!
Hello,
Is there an option to blinkout the Anduril Version?
I think, if it´s Anduril, it´s Anduril 1.
Has Toykeeper one page with the differences listed between the Anduril versions?
Thanks.
I have not been able to figure out how to attach pictures here, either. I do not use online image hosts. I attach my pictures on another forum, where I pay one cent per hour to not have to deal with image host sites. I am glad that you got your HK 90. I ordered my HK 90 from Banggood group buy on September 7, but it has not shipped yet.
You really can't overdrive 3 SBT90.2's on 3 40T's, or 30T's for that matter, regardless of FET and thick wires used.
My GT kit upgraded to a GT90 is probably about 30 amps for just one LED, but that's an incredible 8P battery setup.
Would be nice to have a 6 cell battery tube option for this light, but that would require GT style carriers.
I've de-windowed a few GT90.2's. Could expect a 5%, maybe up to 10% boost. Side by side, I can't see any difference in the beam tints but that could be me - 62 year old eyes
I'd probably do the dirty de-window deed on the HK90.
