That would be a scam!
Circle (2015) ⭐ 6.0 | Drama, Horror, Mystery
1h 27m | Not Rated
Average Rating: 6
Duration: 01:27
I’ve yet to find 12,000 mAh 18650’s, but I did find 10,000 mAh ones
3.Use 8 high-quality 18650 cells
I wonder how many lumens a space shuttle launch was. They were very bright at night.
Naquadah reactor sold separately
Nah, you’d probably need naquadria instead.
that’s a typo, it’s actually mEh , NOT mAh !!
80000 mEh , eh??
Reminds me of when I bought a 5 megawatt laser pointer for £2. Turned out they meant mW, not MW.
I present for your consideration the 90 trillion volt stun gun flashlight. Imagine the turns ratio on that transformer.
It's a good thing it's called a Terminator, because a 90 trillion volt stun gun would kill you!
I think the person handling the taser will die/fry too. Voltages that extreme will most likely arch to the hand of the one that holds it.
Most likely only the person that holds the taser will die because the power draw is so extreme, the battery will overload and explode in a split second when turned on.
A typical lightning bolt is only 300 million volts. The clouds got nothing on a chinese stun gun.
You are forgetting one important thing Pip…
The clouds in the taser are in series
It’s a good thing it’s called a Terminator, because a 90 trillion volt stun gun would kill you!
1h 27m | Not Rated
Average Rating: 6
Duration: 01:27
I love posting this image every now and then…
I believe it’s from a HKJ review.
Looks like a rewrap of this cell which HJK rated “very bad”. Harsh judgement if you ask me, because it delivers a whopping 45 mAh at 5 amps
The brand name is the best of it all. In my language GIF means poison
!https://lygte-info.dk/pic/Batteries2012/GIF%20ICR18650%2012000mAh%20(Yellow)/DSC_8829.jpg!
Here are some more 12000 mAh 18650s:
(EDIT: Removed the link, because apparently “No need to link to horseshit” hehe)
Dutch detected!
[quote=ZoomieFan]
Only one review. One star. Probably about the UI. Which one of you was it? Just because a light doesn’t come with Anduril doesn’t mean it’s bad. Sheesh.[/quo
I’d be interested in this if there’s a 18350 tube.
Interested. Can you get get an 18350 tube for this light?
But assuming it doesn’t explode in a fireball when I turn it on, when my idiot neighbor saw it he’d have to get one too and I’m afraid he’d set my house on fire trying to see in my teenage daughter’s window.
On the plus side, it probably would stun your attacker. I know I’d sure be stunned if the person standing in front of me suddenly combusted in a thunderous explosion.
Life time warranty? I guess they mean user life?….
