Could I please have a coupon @freeme??
Ordered a red one.
Thank you.
Got my greenie. Guess I didn't read the fine print - didn't realize it's a UI all their own, not Anduril, no AUX LED's around the LED.
I measured 4.2 tail amps on a 35E at 4.06V, but on a VTC5D, measured 5.2 tail amps. So, what does this tell us? Is it a FET with limited amps or just poor regulation?
Don't think it's a problem for the green - think it can take higher amps than the white or red?
Would also like to know if the green does take higher amps than the white and red (as mentioned in another thread, the red didn’t seem to have visible brightness difference when on High or on Turbo mode), whereas the white one will turn a bit bluish on Turbo. The green looks a wee bit brighter from High going to Turbo, again as per the sample I got of the FT03-Mini Osram (white/green/red)
Do you maybe know if any code is available for:
Stainless Steel Bezel for Astrolux FT03 Mini
Thank you
Kind regards
Interested !
Sent.
Does anyone know how this will compare to the Manker MC13?
Interesado!
Freeme – Can I get coupon codes for FT03 Mini SST40 & XHP50.2
I would like to buy a few of each – Thanks
Interested!
Still interested. Can I get codes please.
interesting
Info shared.
Sorry for the delay as we were busy working on our site.
Thank you - ordered 4 Blue
Thank you for you support, Deeuubee!
Interested
Bummer! Just got emailed that the lights I ordered last week are out of stock.
Freeme… please light a fire under them to make more.
I have been reading data sheets on all nm1 colors and they are all pretty close (+/- .75a) to each other if I recall correctly. I ordered blue, red, green and I got green, white, orange. Green is great, orange is pretty good too. I ordered blue and red nm1 on 20mm mcpcb from Neil to swap out orange and white (white sucks kindve). I’ll post pics of before and after as I will have all 5 versions at that point
