Test/review of Shockli IMR14500 1050mAh (Orange) 2020
Great overview. The Vappies also have a good price.
Thanks for the results SKV89!
Seems like the Vapcell and Shockli are really shoulder to shoulder and are the definite 14500 top cells so far :wink:
However, while the Vapcell H10 have already returned to the market, I don’t see the Shockli yet :zipper_mouth_face:
Should be available soon. I was asking Shockli-Simon to sell me some since it was originally tested by HKJ. Waited half a year and they finally have them available. Have you checked Aliexpress?
Yup, just checkef again and they don’t have it.
I am served now, but wouldn’t mind grabing some of these !
Will keep on checking their AE store!
Btw, the Shockli Orange 1050mah is a flat top that works in the GT Micro. The Vapcell H10 flat top does not work in the GT Micro. So not sure if they really are the same cell.
I’d be absolutely shocked if they weren’t the same cell. Everything looks the identical. It could be something as minor as a different insulating gasket and/or thinner wrapper that makes the difference.
I’ve had this before with Windyfire Red 14500 FTs. Two of the four I bought at the same time would work in an Eagletac D25a, two would not. Microns different in protrusion of the positive contact was make or break. Crimping variation easily could account for the difference I measured in that case.
4 of my Shockli 1050 flat tops worked in the GT Micro and both the Vapcell H10 flat tops didn’t. But it could simply be due to batch to batch variation. The chances of them being the same cell is high.
I think there’s also variation between GT Micro’s, I got cool-white & neutral-white GT Micro.
I don’t have these Shockli 1050mAh and Vapcell H10 flat-tops, but I tried some other flat-top 14500 batteries on the GT Micro.
What’s surprising is that some flat-tops work on one GT Micro, but doesn’t work (not making proper contact) with the other GT Micro…
Got flat top Vapcell Gold from Nov 2018 and flat top H10 from Neals included with GT Micro copper recently delivered. Both work in original GT Micro and the copper.
Good news guys. These batteries are available now and are slightly cheaper than the Vapcell H10. Unfortunately, only a flat top.
Shockli 14500 1050mAh
Fortunately their flat tops protrude a bit more than the H10. 4 of my Shockli Orange 1050 flat tops works in the GT Micro and both the Vapcell H10 flat tops didn’t.
Specs: 49.1mm Length
Ali link specs: 50mm Length
Can anyone verify which is correct?
Thx
Just pulled the trigger on 4 of these :person_facepalming: :money_mouth_face: :sunglasses:
What aa lights do you plan running the Shockli 12a ?
My Jaxman E3 triple w/ LD-A4 9A driver, from led4power :wink:
And my BlitzWolf BW-ET1 modded with XHP50.2 (with 15mm driver with Anduril, this one takes 2 x14500) :+1:
And eventually other 2xAA lights that I will mod in 2x14500 with XHP50.2 :smiley: (Tool25 and a 2xAA Livarnolux zoomie).
And in my Tool AA lights when I receive some DTPs to replace the thin aluminium PCBs. They’re running with 15mm drivers with Bistro HD OTSM by Lexel.
:innocent:
Livarnolux zoomie, i read review, looks well built host
No English translation directions not an option, bummer!
What are those? My Tool AA 2.0 gets hot pretty quickly with the KP CSLNM1.F1 on the stock alum board. :stuck_out_tongue:
Tim, Convoy Store and KDLITKER both sell DTP (Thermoelectric separated) MCPCB
Cu Mo beta than Al
These: 5.94€ 5% OFF|KDLITKER 3535 10 DTP Kupfer MCPCB für Cree XP Serie/Nichia 219 Serie/3535 LEDs|Tragbare Beleuchtung Zubehör| - AliExpress
:+1:
What is best source for US customers for Shockli (orange) 14500 1050mah… Aliexpress Shockli Store ?
