You really can't overdrive 3 SBT90.2's on 3 40T's, or 30T's for that matter, regardless of FET and thick wires used.
My GT kit upgraded to a GT90 is probably about 30 amps for just one LED, but that's an incredible 8P battery setup.
Would be nice to have a 6 cell battery tube option for this light, but that would require GT style carriers.
I've de-windowed a few GT90.2's. Could expect a 5%, maybe up to 10% boost. Side by side, I can't see any difference in the beam tints but that could be me - 62 year old eyes
I'd probably do the dirty de-window deed on the HK90.
1lumen has their review up. Looks like 688kcd at startup and dropping like a rock. I didn’t see a 30sec value posted but the output graphs would suggest it comes in around the mode 7/7 value of 234kcd. If thermal config were adjusted I’m sure this would sustain more, but three 90.2s in a handheld is silliness to begin with. For the sustained output and throw this light can achieve, it really makes little sense to me. A K65 w/ 70.2 will do the same (sustained) numbers in a smaller package.
To me it looks like temp calibration wasn't done, or done properly. Yes, there's a lot of heat but it's a pretty big light, lots of metal. If I can get 30 amps out of a tiny Amutorch X9 w/triple XHP50.2 3V's, certainly 60 amps in the much much larger HK90 is do-able, and can run 30 seconds without scorching fingers.
It’s obvious that the calibration or tuning is way off. I’d expect it to sustain 7-8k lumens without fan cooling if it’s allowed 65C. It should definitely be able to keep above the 10k mark for 30-60 sec.
I have lots of rocket lights that have graphs of "instant drop like rock" performance, and I still love all of those types of lights, in all sizes.
I am going to love this light, when I get it, because it surpasses the X65 in throw and lumen specs in the same weight package with cells.
I have a 22 digit tracking number, and it was shipped, but I can't find out what part of planet earth the package is at. On which package tracking website can I enter my 22 digit tracking number to see where the package is?
22 digits matches up well with USPS, assume you tried them. I suspect mine is out for delivery, though the linkage from shipping company to USPS wasn't made clear.
"22 Oct 202023:42: USPS Currently Awaiting Package. A status update is not yet available for your package. It will be available when the shipper provides an update or the package is delivered to USPS. Check back soon.
USPS
07 Oct 2020, 05:41, Shipment information sent to FedEx
FedEx 07 Oct 2020, 05:41, Shipment information sent to FedEx 91730"
To sum: 14 days later, the package is not below the surface of the earth, and the package is also below Heaven. I can relate, because that is also where I am currently located.
