Today was coloring and gluing (and waiting for everything to dry) day....
First I had to scrub all adhesives residues, dirt etc. that came with the light
And wait till it dries....
Than I applied several layers of black matte color
But it was worth the wait. I am very happy with the result. the matte is lot nicer than the original color (although I have no idea why they use color instead of anodize)
And the last two steps for today were toe screw the cable gland (had to drill it to 5.5 mm to fit my cable) and glue the switch (as you guys advised) I used the heat sink plaster for this mission. It is strong enough (but not permanent) and will will defiantly withstand the heat
You have to love the old tools. Glad the vice is still being used.
Good to see more headway on the torch.
Today was "soldering and assembly" day:
I glued the pill, driver, LEDs and optics to the body using heat-sink plaster
Then drilled thru the PCB and body holes for wires and soldered
And finished with soldering LEDs and driver, it finally starts to look like a headlamp
I have already burnt a FW and tested it and it works great but I still have to modify the battery box before further tests, I have some interesting plans for the box :)
Cool. Looking forward to seeing what is planned.
As promised, Today I worked on the battery box.
For those of you who are unfamiliar with caving lights, the battery box is placed at the back of the helmet and connected to the front part with a cable. It enable carrying many cells while distributing the weight evenly between the front and the back of the helmet, preventing the helmet falling over your face.
The original battery box was design to perfectly fit a 3S1P 18650 pack - I don't like packs since: you can not use the proprietary pack in other lights, cannot borrow or lend batteries from/to your friends during long trips and have to carry 2 sets of spare batteries: one for your main light and one for you backup light (which is usually smaller and use single cell).
I also didn't like the fact that the cable went out of the box on same direction as the nuts for closing the box. That way, if you place the box so the cable going down, you will probably lose a loosen nut and if you place it upside-down the cable is placed vulnerably and may get cut in tight passages.
So first, I drilled a new hole for the cable and placed a cable gland at the bottom of the box
Second step was to replace the battery pack with a 18650 battery holder so I can use regular interchangeable cells. I had to use 2 cells holder instead of the original 3 cells pack but I think it is worth it. (it is also less wight on the head).
I used the extra space for adding a USB charging module so it is easier to charge the cells at home or using a power bank at the filed.
This circuit also have a low voltage protection and it is a nice bonus.
I secured all the wires using hot glue to prevent damage over time caused by motion of the helmet. It does not look so nice but it is hidden in the battery box.
Last step was to verify charging and protection is working as planned.
I placed the charging module at the top of the box so no need to take the holder out to charge it and the indication LED are visible
Nice progress.
Looking good YuvalS.
Just completed the last two tasks: battery box cover and final assembly:
As I mention, the original battery box had the cable glad on the cover, since I placed a new cable glad I had to make a new cover from Perspex piece I had a home.
I also cut some rubber to waterproof it
And just wanted to make a new post for the final result pictures (with last year build too):
Now I only have to find a dark location for taking the beam shots
That looks so professional YuvalS. Lor have made a real sweet torch. I hope you can put it to lots of use.
Finally Moon is not so bright and I was able to take some beam shots:
The sandy ground and the vegetation appear to be like the southwest US
It is Caesarea. Had to drive a bit to find a dark place.
Nice finish YuvalS.
Very cool headlamp YuvalS. I like the different beam profiles, better than a zoomie in my opinion
YuvalS, Sorry I missed your Finnish :person_facepalming:
Your light looks very rugged and ready for caving or anything you can throw at it.
Great job on your modification build, although it looks like a handmade build. The driver board from scratch is something only a few here at BLF have done, so much to know and successfully make happen. You worked and planned very well on your competition mod build. We all enjoy and learn from you guys who make BLF such a nice forum, Thank You :+1:
Cool
MRsDNF, pinkpanda3310, CNCman and MascaratumB, Thank you so much for your support and encouragement, hope my build helped and encouraged other BLF members to build their own caving lights or any other type of lights, I know I have learned so much from BLF members and the OL competitions, looking forward to the the final resultes of all the cool builds this year :)
Really nice build . Looks well thought out
Impressive effort with making your own circuit board and FW! I love these purpose-built tools. Also I find that when you are making a tool with a more defined purpose there are more constraints in the design process and I enjoy it more.
Caving sounds exciting. Can you give some examples of when you would use the different beams and how often you would switch between them?
