I have one and it’s a lot smaller than I’m looking for, I want something heavy duty and about 10”/25cm overall. The Mora (Bahco 2444) is about a inch and a half shorter has a delicate thin blade.
I have a Bahco 2449 wrecking knife and a Hultafords Heavy Duty GK knife which are both bigger and have thicker blades but I’m looking for something bigger than those as well.
That looks like a great alternative to the Prawn. The thinner 0.12" blade stock should be a much better fit for that blade length. The S35VN should be much better for EDC.
I haven't tried any of the premium Bestechs but my experience with their budget knives has been fantastic. Fit, finish, and action are all excellent and have actually improved since the Pebble was released. If you end up getting one of these, please share your experiences with it here.
Beyond that, do you have any preferences regarding steel, sheath type, etc.? For another $10, you could get a Ruike Jager. The Jager is a very nice fixed blade. It's a little more compact but still a good size. I prefer that kind of sheath for regular carry. It's also 14C28N. Its particular balance of toughness, edge retention, and corrosion resistance makes 14C28N a great choice for fixed blades.
I recently purchased this J. E. Made Nessmuk. I don’t know anything about the manufacturer but I believe they are a Chinese company. This is a superb knife.
I have the same green QSP Penguin. Got it from Drop. But mine has a very weak detent and the blade easily falls open, so I’ve never carried it. Don’t want to reach into my pocket and get surprised by a sharp blade.
I also have this knife and mine is decent. Like some other people here, I got it on Drop when the price was irresistible.
Remember that things can go wrong in production. Every once in a while, a lemon can squeak its way through Quality Control. That seems more common in this tier of budget knives. Besides trying lots of different budget knives for myself, they tend to be my default gift for others (in addition to flashlights). I inspect, clean, and lube every single one of them including disassembly whenever possible. I've seen issues with QSP, Ganzo, CJRB, Tangram, and even Kizer's Vanguard line. If it's something I can fix myself, I do. Otherwise, I contact the company. Most of the time, they want to make it right. So if adjusting the pivot tension doesn't work, contact QSP.
I have about 14 mora knives. I bought different color ones and made a display rack . The 4 or 5 I actually use are sharp and so far indestructible.
Since I have OCD I have to buy multiples of everything. Watches, guns , knives , gas masks , swords , medieval helmets , flashlights , guitars (I can’t hardly play) whatever .
I have a bunch of models as well. The only one I found lacking was the fracture which was not very sharp on arrival. I tried to strop it and it got worse, so I had to sharpen it on a stone, a skill which I’m still not very good at. It’s a little better now but I havent used it, kinda bought it on a whim since it was so cheap at $30.
I did have an elementum with a stripped pocket clip screw and the clip would move out of place, was able to order some new screws from them and I loctited them in so it’s good now.
Really like the Ortis, very solid and low cost. it has a similar blade shape to the Dogma, but Dogma has better closing action.
