Hey Barkuti, no problem, it’s always good to hear your 2 cents.
Don’t know, maybe warm white is better. Maybe red… :nerd_face:
I’ve decided to start with yellow since I remember some cars use yellow anti-fog lights. Warm white is typical for old-fashioned bulb lights and for some reason somebody decided yellow will suit better.
But it may also be some other color/wavelength is better (e.g. green or red) but not commonly used due to interference with colors meaning.
Well, first I’m gonna build the light, then we’ll see if any difference can be spotted.
I would be happy with that as well
My wallet won’t, since i need to buy three new (matching) cells which i need to hold together.
Plenty of 18650’s though
Will the 4x18650 version require to use button top batteries? If so, I will look forward even more to seeing the 3x21700 version.
Why? Because a) button top batteries are harder to get and b) button top batteries often add significantly more contact resistance, especially those with cheap joint-welded buttons that tend to rust quickly.
My hopes are that these new lights have a different battery compartment with brass buttons on the positive poles of the head unit instead of a brass ring (which requires buttons on the batteries).
You mention, that driver has 4.8A current, but for this CSLMN1 specific tint (.FY), only between 2.5-3A is recommended. Above 3A, output flats out, and at ~5A, output is even less, than at ~3A - this means, efficiency drops very fast.
I think all the yellow CSLMN1 variant has the same specs as the white variant in paper. The white version output peaks at 4.5A-5.0A according to a test and 5.75A according to another.
I can’t find any test for the yellow variant, do you have one? The datasheet only shows data for up to 3A as for the white version.
