Fireflies NOV-MU 21*Nichia E21A mule 1x21700 Flashlight --in stock
That would be an interesting tint mix. Luminus Xnova Cube 1800K CRI90 is similar size to E17A, so it might work too.
Maukka did it: [Reference] Nichia E17A/E21A (2000K - 6500K, R9050/R9080, color) CCT and tint shots - #49 by maukka
Maybe I was a bit optimistic about R9, but still, it could be nice.
But Luminus Xnova Cube 1800K is clearly better in terms of CRI (Luminus Xnova Cube 1800K 90CRI tested).
So, either E21A 2000K or Xnova Cube 1800K for the candle light fans (including me).
Most of the flames I measured were ~2000K, not 1800K, candle, match, lighter…
Plus this Xnova cube has a positive duv and lower current capabilities as well as output, I don’t see much point in it.
Maybe there is some interesting mixes to make with E17A, but not amber+red, maybe several 2000K+1*red.
Yes, for Amber + Red E17A, the term “candle light” does not apply.
But aside from that, there should be something in between of candle light and red. The term “lava light” could be it - anything in the 1300K to 1500K range. I would definitely get one, once I see one properly designed and implemented.
Interested around 2000K or 3000K
Very much interested if this can supply sustainable high output.
What would be the time to production for this?
Reserved
Post #12 ‘should be available next week’
I remember someone measured a candle and it was close to 1800k. The flame from cigarette lighters is probably different from a candle as you can see more blue flame. I will measure a candle next time during my kids’ birthday.
Any warm light with positive duv is an absolute no. It will make things appear too yellow/orange. The E21A 2000k Ive tested is nice because it is just on or slightly below the BBL .
If you look at Djozz’s measurements of the Luminus 1800K, the CRI and R9 is no match for the E21A 2000K. At the lower output levels, the E21A is 95CRI with R9 above 95 despite rated as 9050!!!
Also with the Luminus 1800k, you can see the DUV is a whopping +0.0042. At those warm temp, such a high DUV will render everything uncomfortably yellow. If there exist a below BBL bin, that would make this emitter more interesting but it still won’t have the candle like color rendering of the E21A.
PWM is absolutely a no-no for a photography light. For this FF mule, it will not have PWM for the regulated levels so I will be switching over to this as my light for sure.
Of course, E21A 2000K is superior in every way except it is not 1800K.
Luminus Xnova Cube 1800K CRI90 is better than other amber leds with 1700K or 1800K CCT. I would try a Lee Zircon 803 or a Lee Zircon 802 filter to decrease DUV.
A bit off topic, but using official specs for red and osram color calculator :
2000+red : 1325K duv –0.0040
2x2000+red : 1505K duv –0.0040
3x2000+red : 1683K duv –0.0033
No idea about color rendition since I don’t have red spectral data.
So using Virence quad mcpdb you can mod yourself an ultra low CCT light (or ask him for a mod)
I’m quite the pillock……
Awaiting the reviews!
Well, I am not nearly as skilled, as I could safely make experiments with Virence MCPCBs, so I just hope, somebody other will :innocent:
These look really interesting.
I would be interested in a 4500k or 5700k.
Beamshots? These would be very flood lights right?
Any chance for tint mixing? 3000K on the 12 outside E21 and 4000K for the 9 center index or something similar?
These lights will have no beam at all - just 180° of pure flood.
interested in:)
