Will the 4x18650 version require to use button top batteries? If so, I will look forward even more to seeing the 3x21700 version.
Why? Because a) button top batteries are harder to get and b) button top batteries often add significantly more contact resistance, especially those with cheap joint-welded buttons that tend to rust quickly.
My hopes are that these new lights have a different battery compartment with brass buttons on the positive poles of the head unit instead of a brass ring (which requires buttons on the batteries).
You mention, that driver has 4.8A current, but for this CSLMN1 specific tint (.FY), only between 2.5-3A is recommended. Above 3A, output flats out, and at ~5A, output is even less, than at ~3A - this means, efficiency drops very fast.
I think all the yellow CSLMN1 variant has the same specs as the white variant in paper. The white version output peaks at 4.5A-5.0A according to a test and 5.75A according to another.
I can’t find any test for the yellow variant, do you have one? The datasheet only shows data for up to 3A as for the white version.
I have the Noctigon K1 fitted with the specific variant, CSLMN1.FY, and my K1 has even less output at 5A, than around 3A. So you can trust me.
Also, you should look for CSLMN1 specifications for other tints, and you will need to compare If (forward current) vs. lumen output graph carefully for each of them, and then, you will see, that for the Yellow and the True Green variant, output starts to flat out much sooner, than for other variants. Also, those graphs are probably for a close-to-perfect soldering work, which will usually not happen. So, for less-than-ideal situations, that output will flat out even sooner - this is why we need to examine each kind of emitters (or at least make use of the graphs as well in the specification, no just the basic stats), and choose safe driving current accordingly.
Hank stated to me the K1 drivers are not being tweaked per LED type (at least the white W1 is the same as the green W1), so this is not surprising. Each of these color specific W1's have their own output curve with a different peak current, and Hanks and Simon are not properly configuring their drivers accordingly. Of course the other variant is the quality of the LED reflow, also assuming it's on a known good 3030 MCPCB of course.
At least with the K1 you can swap a resistor to control the amp output - maybe can do the same with Simon's driver.
Emitter technical name is CSLNM1, not CSLMN1 fellows.
Concerning driving current, as you approach peak output the gains with the increase in current get smaller and smaller, until they dissapear or even turn into losses. Thus, with all the above variables given it is wise to settle for a 75 or 80% of the peak output driving current, that way above 90% of the peak output is still attained and emitter stress reduces considerably.
I guess it may depend on the type of payment you are using . Once I tried using virtual credit card and couldn’t do it, so I needed to use PayPal to place the order.
Once you add the payment method click on “place order” but don’t advance for payment, and abandon that “screen”. After Simon adjusts the value, you can go back to the order placed and choose another payment method (as I didn’t want to use PP, I added a virtual card for single use) or the same.
In your store the cslnm1 comes bare or on mcpcb, what diameters are available for the mcpcb? I need to measure mine but just seeing if you have options.
Also, can you sell board mcpcb only for the CULPM1? 4040 footprint that is. Thank you!
This is what a user of AliExpress outside of China can choose right now as payment methods:
AliExpress removed the other payment methods from their international website sometime ago. As far as I am aware the only option is to use an old version of the AliExpress application, 8.4.0 or earlier to be more precise (you can download it in Uptodown.com, for example). Warning: the app checks for updates on startup, and records the amount of times it has moaned about updating; it eventually refuses to work without updating if you allow it to keep checking, so it is best to disconnect from the internet just before opening the app, and reconnect to internet once the app is about 10s launched (to dismiss the app update check).
With an old version of the application (8.4.0 and earlier) it is possible to select “other payment methods”.
Hard workaround to make an order work! If you order many small items from Simon the shipping costs for each item get totaled and skyrocket even though they will all go in one small package. I ended up for now ordering the same items elsewhere on aliexpress with free shipping until there is a way to work around this. It shouldn't be so difficult just to order something.
