Emisar 21700!!!
512 posts / 0 new
niajef
Last seen: 4 weeks 1 day ago
lightdecay wrote:
If you have SBT-90.2:
https://www.illumn.com/21700-molicel-4200mah-inr21700p42a-45a-high-disch...
All other emitters:
https://www.illumn.com/21700-samsung-inr2170050e-5000mah-high-discharge-...
am i correct in assuming that its because sbt has a high drain? while all other emitters, including osram, are sufficiently handled by 10A discharge? does this make sbt run time less?
and also, it seems sbt advantage is high lumen? but whats the point of high lumen in a dedicated thrower? isnt kcd more important? the osram 2.1 having 650kcd will still have higher beam intensity, aka look brighter, than the sbt, no? sorry im still very new, just gathering pieces of information trying to put them together.
lightdecay
Noctigon K1 with SBT-90.2 can use FET turbo, while other emitters can only use regulated mode up to 5A or 7.5A max current.
SBT-90.2 has a much bigger hotspot, but because it can put out more lumens it also has very good throw. Other emitters have very good throw, but the hotspot is much smaller.
I recommend SBT-90.2 if you can afford it.
https://budgetlightforum.com/node/71340
niajef
ya i see its 50 bucks on top, thats quite deep…i think maybe ill just stick to osram, its meant for pure throwing anyway, dont need a huge hotspot
stephenk
stephenk's picture
Last seen: 10 hours 13 sec ago
21700 Emisar lights would make sense!
Hank Wang
Last seen: 1 hour 7 min ago
Hi, guys, new 21700 light will be released soon, with Noctigon name.
https://intl-outdoor.com, Noctigon, Emisar, flashlight components.
Kajman
Great news, flooders or throwers? I still look for something what would keep high lumen flood on bike night rides better than Emisar D4s. Emisar lasts longest time when outside temp ist about 8*C.
Hank Wang
The name is Noctigon K9.3, guess how it will be like Cool ?
TMaxxJJ
Last seen: 44 min 53 sec ago
This is great news!! Will it use the same battery holder (with charging function) as the K1?
TMaxxJJ
9 emitters in 3 triples?
Hank Wang
Yes
Kajman
9 leds?! It will be huuuge… 3×21700?
Hank Wang
If it’s like that, then we can simply call it K9, or K33, not K9.3.
TMaxxJJ
Hank Wang wrote:
Yes
My poor wallet!
Kajman
Is date known? Smile
Souichirou
Souichirou's picture
Last seen: 3 hours 4 min ago
OHHHHH ! I cant wait to see what it is ! either way ill more than likely take 2-3 =D
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 2 min 2 sec ago
Hank Wang wrote:
If it's like that, then we can simply call it K9, or K33, not K9.3.
K9 always reminds me of... Big Smile
K9.3 could mean...
  • 9 emitters where 3 of them have a different tint than the other 6 ones? Multi-channel operation to ramp tint?
  • 9 emitters with a big tube using 3x 21700 batteries? I don't think so because it would mean a veeery big head diameter, right?
  • 9 as in SBT90.2? Maybe 3x SBT90.2 with only one 21700 battery? Nah....it would drain the battery in seconds. Big Smile
I guess the only important question will be: WHEN will it be available? Because most people will say again...
Will you send a sample to ToyKeeper before, so we get a great review again (as usual)? Wink
adam7027
Last seen: 15 hours 5 min ago
Hmm… maybe wrong guess, but what if it is 27× E21A? Party
lightdecay
Emisar D4SV2 is now only available in black, which suggests that it will be discontinued soon.
This flashlight could be a D4SV2 replacement.
Hank’s posts suggest that Noctigon K9.3 has 9 emitters and uses 1×21700 battery. A flashlight with 3×21700 batteries would be bigger than Emisar D18 and would probably have at least 18 emitters.
Since tint mixing is popular, my guess is that Noctigon K9.3 could have 9 emitters in 3 groups that can be driven independently for tint mixing. However, it would not use triples like Noctigon Meteor M43, but the same optics as Emisar D18.
Ryzbor
Ryzbor's picture
Last seen: 21 hours 27 min ago
Yeah nice, and I just bought 3 Shockli 26650’s
virence.com Nichia E21A sw30+sw40 Wizard Pro ; Skilhunt H03 XP-E2 660nm ; Wizard Pro E21A 2000K ; S2+ E21A sw40 d220 ; Sofrin C01R 660nm, Mf01 Mini Nichia 219B sw35+sw40
EmptyWallets
Last seen: 1 week 3 min ago
MAYBE Triple SBT90 that’s the only 9 I can think of. But that would be $$$
justanotherguy
Last seen: 2 hours 20 min ago
Geezuz hank..
I haven’t saved up for my replacement K1 even….
Hank Wang
Naming a flashlight after an LED model name would not really be our style, so, this flashlight does not use SBT90.2 LED.
niajef
you’re killing us!!! can you at least give us a date for the announcement
jp9mm
Last seen: 6 days 1 hour ago
Will it have auxiliary leds?
FlashIight
FlashIight's picture
I’m dying to know more about this Noctigon K9.3. Any updates?!
jp9mm
Hank Wang wrote:
Yes
Nice this was my suggestion too. We’ll just assuming the heads will be swappable?
niajef
hm, that somehow gave me an idea, well just a thought really, is there such thing as a two-headed flashlight? not like a two-headed dragon, but like a double dildo…if that can be done, like a k2, then the k series can officially be called lightsabers, its got one end ones, two end ones, and all have different colours.
Rusty4x4
9 led flood, 3 led throw, “zoomable” by varying the current to each emitter group similar to how the LT1 does tint ramping?
Lightbringer
Lightbringer's picture
Last seen: 6 hours 56 min ago
They exist, but you gotta buy ‘em at the Darth Mall.
niajef
really? not the jedi mall?
