also, whats the purpose of that red aux exactly? like a real life practical use case
Red is good if you want to navigate without killing your night vision (dark adjusted eyes). Also, as a hunter, it doesn’t spook wildlife.
Sofirn and 77Outdoor are like cousin companies I think. Barry works for Sofirn and is active here on BLF.
OH! well thats some back story i didnt know…thanks
so you would recommend wuben h1 over sp40 any day of the week then?
is there anything better than the h1 in this price range? under or around $30
If you want the output to be consistent and regulated so that the light doesn’t gradually dim over time as the cell voltage drops, then the Wuben H1 is better.
right, i was wondering if theres any other ones around the same price that could maybe do like 600lm or 800lm, also regulated, or more/better features
Thanks for the review gchart, very informative.
I can’t tell from the picture for sure, but it seems the P9 diode is integrated with the pcb, and the black plastic sheet around is the washer. Please correct me if I’m wrong since I’m not sure what is the white round thing underneath. Could it be the LED mcpcb?
PS: you’re not that ugly, but I like only girls
PS: you’re not that ugly, but I like only girls :laughing:
Good question! It appears that the driver board has a circle cut out of it and that an MCPCB with the LED sits in that cut out. Interesting, space saving design, huh?
everybody goes through an experimental phase
This WTF P6 led must be replaced immediately ;))
If you demand another CCT, then sure… but what makes you say that? P9 is 3737 BTW but I bet you could probably do a 3535 ok. Or I guess shoehorning a new MCPCB would work.
I wish I hadn't just spent $30 on a Wowtac A2S. I would have picked the H1 instead. The A2S needs some DC-Fix to make the beam more my preference for a headlamp. The H1 not only has that full flood capability I like, but regulation, a brighter main light and a red light too!
Thanks for the review.
Just gift the Wowtac to someone this Christmas and get yourself an H1
i need to make more friends like u
I already bought two Wowtac A2 headlamps and two W1 EDC lights to give to as gifts to some non-flashlight people.
hey gchart, i just got a sp40 from amazon to try it out, and i realized i needed the lamp to be able to rotate easily, as in a built in functionality to rotate, not manually force the rotate. cuz the sp40 is strapped by 2 rubber rings, and if i want it at a different angle, i have to forcibly twist the light past where i want it, due to the give that rubber rings have, then let it turn back a little bit by itself to get it where i want it. i dont like this mechanism at all, and by the looks of it, wuben has the same design?
A ton of headlamps are the same way, including the Wuben H1. The only one that I’ve had be different was the D10/D25 headlamp which uses a hard plastic bracket.
wait which brand? i been seeing a lot of d10 and d25 recently
There are a bunch of brands of the same white-label headlamp. Commonly going by Boruit, but many others. D10 being the single emitter, D25 being dual emitter. Sofirn has their D25S, which is a customized version of it.
Boruit D10 / EHL0628 [image] So I’ve come across this well-liked budget headlamp which I believe to be much better than the well-liked cheap Boruit RJ-02. The only review I am aware of posted on the web is a Russion review found here (translated via Google Translate). I decided this headlamp deserves its own thread, so here are some pics and a quick review. Doing some investigating I came to the conclusion this light is model #EHL0628 (EDIT - more widely known now as the D10), as shown in this…
Seems quite similar to the excellent Nitecore HC65.
