damn, still no a3 pro
Is the diffuser made out of rubber? It looks like a hard plastic.
2020 Singles Day & M4D Sales
veröffentlicht am 10. November 2020 in flashlights von m4d m4x
Hello my dear friends!
Here are my deals for this special sale – if you find more let me know and i add them!
-> SHARE THIS PAGE SO YOUR FRIENDS CAN SAVE $$$
https://www.banggood.com/custlink/GmKd5SmuU7also try my code for better deals on many items!
28% OFF Coupon: BG1128
[Astrolux 5th Anniversary Limited Edition]
Astrolux® FT03 SST40-W Copper/Brass
2400lm NarsilM v1.3 875m Long Range Flashlight 2A Type-C Rechargeable 26650 21700 18650 Thrower LED Torch
My Code: M5thLD
Your price: $71.99
Astrolux® FT03 XHP50.2 Copper/Brass
4300lm 735m NarsilM v1.3 Thrower LED Flashlight 2A USB-C Rechargeable 26650 21700 18650 Strong Torch
My Code: M5thLD2
Your price: $76.99
Astrolux® FT03S SBT90.2 Copper/Brass
4500lm 1428m Anduril UI Thrower LED Flashlight Long Range 21700 26650 18650 Powerful Flashlight
My Code: MA5th03
Your price: $96.99
[NEW]
Astrolux® FT02S 4* SST40 7000LM
Ultrabright Anduril UI Strong Flashlight 639m Long Range 18650/21700/26650 Powerful LED Torch
My Code: :MA5th23
Your price: $40.99
[NEW MODEL GROUPBUY]
HAIKELITE HK4S 4x SST20 4000LM 650M
Super Bright Long Range EDC Flashlight Type-C USB Rechargeable 21700 26650 Powerful LED Torch
My Code: :MHK4S1
Your price: $38.99
HAIKELITE HK4S 4x SST40 7000LM 500M
Ultra Bright EDC Flashlight Type-C Quick Charge USB Rechargeabl Mini LED Torch 21700/26650
My Code: :MHK4ST40
Your price: $41.99
PLEASE NOTE!
The prices may rise after the 11.11 Sale!
Ok - the copper FT03 is stunning! I see they left out the weight because that must be a ton of copper! The FT03 is a pretty big light.
Any special deal for the author of the firmware?
The HK4S is also a stunner in a small package - 5000K tint of course. Hhhmmmmm. I really thought I needed to take a break from buying for a while
hi i’m interested in the Rovyvons
what is the password for the copper Rovyvon Aurora A9 copper?
https://deals.m4dm4x.com/2020/11/05/rovyvon-aurora-a9-copper-650lm-usb/
Thank you my friend
Not a bad deal with that seeknite even though shipping increases the price to $14.29.
Astrolux® EA01
XHP50.2 3500lm SST40 616m Anduril UI
TIR Ultra-Throw EDC Flashlight Type-C USB Rechargeable
26650 26350 21700 18650 Mini LED Torch
including lung and short tube!
available in Black / Blue / Grey Body
available LEDs: SST40 5000K/6500K XHP50.2 5700K/6500K
my Code MAEA01 saves you 28%
Specifications
Product name: | Astrolux® EA01 TIR Ultra-Throw EDC Flashlight |
Brand: | Astrolux |
Model: | EA01 |
Emitter Type: | XHP50 / SST40 LED |
Color Temperature: | 5000k
5700K 6500K |
Max Output: | XHP50.2: 3500 lumen
SST40: 2300 lumen |
Range: | XHP50.2: 521 Meters
SST40: 616 Meters |
Intensity: | XHP50.2: 68000CD
SST40: 98000CD |
Firmware: | Andúril UI |
Driver: | FET+1 driver. |
Battery Configurations: | 1x 26650,1x 26350,1x 21700 or 1×18650 Li-ion Battery (Not included) |
Charging: | Integrated charger via USB-C |
Switch: | Electronic side switch |
Material: | Aerospace-grade aluminum alloy |
Waterproof: | IPX7 Waterproof |
Color: | Black, Blue, Grey |
Weight: | 120g(26350 version),160g(26650 version) [without battery] |
Size: | 26650 version:
116mm x 41mm (Length x Head diameter) 26350 version: 81.5mm x 41mm (Length x Head diameter) |
User interfaces:
[1] By default the EA01 is set to use SMOOTH RAMPING. Instant access to TURBO mode is also provided.
[2] A more conventional STEPPED RAMPING UI is available if you like discrete modes level. You can choose how many steps you want.
[3] MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets. To exit this mode, physically disconnect power
[4] MUGGLE mode uses a reduced output.
[5] It has an electronic LOCKOUT for safety but acts also as momentary low light.
To know about the exact source code used in the product, please go to:https://tiny.cc/TKAnduril
1 x Astrolux EA01 Flashlight
1 x Lanyard
Astrolux® Colorful Filter For Astrolux FT03 FT03S (70mm)
The ST04 coupon code is saying "Invalid Coupon Code".
NEW Lumintop Worm damast/mokume/copper/brass/SS available!
coupon: BLACKFRIDAY gives 35% off
Hi Martin, not sure if anyone asked this before, is there a deal possible for the Thrunite T2 ? Not sure even where it is sold.
I need to ask a few
Tnx!
Max,
Thanks for coupons. I’ve been looking for a X9L Copper coupon all over. I’m having trouble seeing the price when I click the link above for the X9L page. Can you persknal message code or instructions? Thank you!
