Anyone else have these cells or have a similar experience with leaking? I too think Lighthound is a great vendor and I don't want to put a warning in the OP unless warranted.
OK, talked with LH. They are conducting an investigation with the cells I returned to them, but stated that my case was the only issue with this batch of cells so far, so at this point they're considering it a fluke. They also said they'd send me another replacement after a discharge/charge cycle had been performed to verify it was a good cell prior to shipment.
The professionalism of LH is truly top notch. Couldn't ask for more. :)
I found a USA E-Bay seller (3-5 day deliv) with what looks to be the same package deal (2 batts&charger) for $32 free ship. What is the advantage of going with a 3600mah 26650 over a 3100 mah 18650 (other then 500 extra mah)? Does not seem like much extra run time.
You would be better going for the protected 26650 trustfire cell I tested, the protection, plus 4300 + mAh at 3 amp discharge. The king kongs rate a little less at the same discharge, see my discharge test from my first post on this thread it has been linked. 4300 mAh is better then a 3100 mAh by 1200 mAh that makes it worth while IMO (50 % more then a trustfire flame 2400 mAh 18650) 3600 mAh is not worth it IMO. But if you don't want protected cells go the king kongs. But you can get 2 x protected 26650's rated at 4300 + mAh at 3 amp and a 1.5 amp single bay charger or a 1 amp 2 bay charget for under $35 USD shipped.
I ordered the Hi-Max 4000mAh protected cells listed in the first post from eBay. Price is up a bit to $30.60 shipped but I know Hi-Max is a very reputable brand and I want protected cells since I will be using them in series for a T-J12. I will report back on my impressions, but I don't have any test capability so any impressions I give will be limited.
$30 is getting up there, if you lived in Australia i would get you to send me one for a quick test then ill send back, i would like to see how they go.
Guys, sorry if this has already been asked/answered, but it’s hard to read 238 comments…
People have mentioned that some of the cheaper 18650 cells are repackaged used laptop cells, or something like that, leading to poor performance and inconsistency. Does the same situation exist with 26650 cells? If not, could we believe that all 26650s are new? If so, then would the cheaper cells be, if not the best performance-wise, at least new and likely to be consistent?
It’s a good question, petey. Like 18650, the 26650 batteries were not designed for flashlight use, rather they were adapted for that purpose. 26650 cells have been around a long time and are primarily used for industrial applications like:
- Portable high power devices
Stationary battery backup systems
Grid stabilization energy storage systems
Commercial truck and bus hybrid electric vehicles ( HEV’s )
So yes, repackaged cells are quite common, I’m sure, which is why I recommend caution and buying from a reputable source. I will not buy pretty, shiny wrapper 26650 cells from eBay, unless I know the seller is reputable. The real danger with 26650 is that many or most 26650 cells are 3.3v, not the 3.7v we use in flashlights. Stick to the list of good (reviewed) batteries - all others? Use at your own risk, same as with all the Sh!tFire wrapped 18650 cells out there.
I was at my local Frys and they had these Tennergy cells for $12.99 each. I was tempted, but funds are tapped right now, maybe in the future. They have weld tabs though so you’ll have to remove them. Tennergy has a pretty good reputation, no history of re-shrinking used cells, grossly exaggerated specs…etc. On the back of the packaging it spec’d a 6A draw steady state and peak draw (short burst) 8A.
They also had 2 others that were 3.2V Li-Po (safer chemistry), but they were lower current draw, and unsuitable for my applications.
Interesting. I wonder if the underlying cell is the same source as as the King Kong? In addition to 18650 cells at Tractor Supply, this is only the second time I've seen/heard of Li-ion being sold at retail.
very interesting information on the last pages, thank you. I didn’t have much time for my FandyFire HD201 since April, in the meantime the 26650 cells got quite popular I think.
I have two Sony LiMn 26650 (made by Molicell?), which delivered easily more than 6 amps in the HD2010 (Maximum= seems to be direct drive). Minimum voltage is 2,5v, maximum 4,2v. I think, in earlier days, max. voltage used to be 4,1v with nominal voltage of 3,6v, but now you can charge them with the normal lipo programm.
I have different RC Model chargers, for these batteries I use the small charger:
this one works very precisely, but some of the cheap chargeres like IMAX aren’t very precise, so be careful
this is the battery:
Sure, the capacity isn’t that massive. But the maximum discharge is 10c (!!), so you could get up to 25 amps, which is a lot. So far no problem at all with them, will buy some more probably. They are safe and powerful. Some shops in Germany sell them, like lipopower.de, an other guy sells them on ebay.
AFAIK these type of batteries are used for Sony Laptops (the smaller 18650), and the bigger 26650 have been around a while, used for power tools, and lately for electric bicycles. There aren’t so many different manufacturer for lithium batteries, most of them in china. Molicell is an Canadian company, but of course manufactures in China.
Some years ago, the “Konion” batteries have been popular amongst RC hobby people, but are hard to get nowadays. I would like to get one of the 26700 cells. Here’s a comparison of these batteries (in German):
thanks again for all the interesting information, for me, 26650 are the future. More amps, higher capacity, and like the sony/emoli, pretty safe.
The only problems I had with batteries so far were NIMH Cells, which burned and exploded. so I think, they all can be dangerous to some extent. I would never buy myself some (fake?) batterys from an unknown shop. They probably get damaged due to the high power LED we use nowadays, ’cos they can’t stand the high current draw.
