Yes, I noticed this on my M21C-U for 4 mode. This happened on high mode turn off(memory) and turn on again. It also happened for from off, double click to high.
I did some testing. This happened when battery is 3.8 volt and below. With a fresh battery, everything is fine.
I just received my L21A CULPM1 last night! I wanted to say these things -
1. this was my first order from you, and my first convoy products (also got m21a CSLPM1) and they are fantastic! Build quality, threading, packaging, and looks. all awesome.
2. I received this order in 18 days to Eastern USA! I think that is amazing. No BS, just order and ship. Really appreciate that!
3. Both lights are VERY impressive! They both throw massively! The M21A with CSLPM1 is iconic - 21700 battery, C8 size, Super light and pocketable, and out throws all others close to its size i have. Look forward to having this as a go to light.
4. The L21A is a TOOL, it is solid, and very nice looking and seemingly unbreakable. Easily programmed it to my desired setting (#10). This thing throws easily with my other throwers of $100+. i couldn’t be happier.
An even cloverleaf is a good indication it’s well-centered. Any “irregularity”, eg, 2 short and 2 long, only 3 lobes, etc., generally means it’s a bit off-center.
The smaller the chip, the more critical it is to center it, and the harder it is, too.
It is pretty even with 3 leafed clover, so guess it is well centred. I tested it yesterday and am pretty impressed for this small form factor to be. Will keep it as is. Also considering to buy L21A or the upcoming SBT 90.2.
