I may have missed it, but is there an estimate of when this light will be available?
I’m interested.
End of the month, I think.
I used several mules with different emitters and for all practical purposes the tint shift at the edge is really not noticeable and will not affect picture taking. The beam is almost a whopping 180degrees wide and the tint shift is beyond your peripheral vision. The tint shift is beyond the field of view of even the widest ultra wide cameras.
I have no problem with Optisolis and Sunlike emitters as I’m sure it will have its own niche. But for the size it takes to accommodate 21 of those LEDs, we can accommodate probably twice as many E21A. Lumen Output would be many, many times brighter and run more efficient with the E21A.
I am sure that a light of given size would have a lot more power under the hood with e21a than that with those low power ones, thats pretty obvious. And for sure, for photography, when one needs just short flashes this power advantage is great.
I hope Jack will take all the time they need to optimize and tune the light before release. No need to rush. I will hold off on buying lesser offerings before this is available.
Sorry, I’m not quite understanding how the constant current buck driver will interact with Anduril.
Will the <6A ramps (while battery V > LED V) all somehow be handled by the buck driver (I’m assuming PWM given that it’s constant current?), and everything above handled by PWM on the FET driver? In which case, it would essentially act like a massive and more efficient version of a 7135 chip? And in which case, wouldn’t the lowest modes have quite poor efficiency from having to smoothly PWM all the way down from 6A?
I’m working with limited driver/electronics knowledge here, so please correct me if any of my assumptions are wrong.
You may or may not get an answer from them on this but here is another buck+fet anduril driver (lume1) from one of our members:
Hello BLF, Hope that everyone is doing well in 2020 and keeping healthy and safe. A few months ago, I was toying with the idea of building a more sensible, everyday flashlight driver, as opposed to my (admittedly impractical) GXB-series high-power drivers. The result is the Lume1 driver. ############################################## Update Aug 2020: Lume1-fw3x is now available for sale thanks to Neal from Nealsgadgets. Buy a Lume1-FW3X! Get the Lume1-FW3X driver from Neal…
In the case of lume1, for batt V > LED V the buck portion takes over and has no PWM with max 3A current. Above 3A your only option is full FET (so no PWM here either).
What’s the candella/ throw on ER12? And the beam profile/ angle?
Thanks
Listed:
https://www.ff-light.com/index.php?route=product/product&path=64&product_id=76
Looks nice. Not really a budget flashlight though and out of my price range but if it gets REALLY spectacular reviews maybe after I get past Xmas and get a good coupon discount.
I wonder what their reasoning was in using XP-L2 HD
I think the era of dirt cheap stuff from China is passing.
Needs a group buy
The optic changed. Looks much better, much less wasted space.
Hope good price
What’s the candella/ throw on ER12? And the beam profile/ angle? Thanks
https://lmxdeals.com/ffl-e12r (affiliate link) states a beam angle of 30 degrees. For better throw, you would want 10 degree tir lens.
Does the light use constant current below 6amps, or does it PWM at 6 amps to get to lower levels?
Why should this be budget? This is a top tier light, so they’re gonna charge around what Acebeam and Noctigon charges.
If the build quality is the same as with the E07 it’s not a top-tier light but just a expensive flashlight.
Cheap flashlights from China are plenty if you look on Aliexpress and Amazon. But you get what you pay for. These new Fireflies lights are not in the same class. Everything is upgraded using more expensive premium parts. For example they will use an expensive Loneocean driver designed for FF. The Loneocean FW3A driver is sold for a whopping $25. This will be regulated and high efficiency unlike the typical Lumintop, Nightwatch, Astrolux drivers that can’t maintain a steady output for practical use. I heard even the springs will see a significant upgrade from the previous BeCU high current springs that were considered high end a few years ago. Even BeCu springs sell for quite a bit from Emisar and Mtn. I’m suspecting the new FF springs will be silver plated with improved mechanical property so they don’t lose resilience (poorer contact and output) that typical for the commonly used BeCu high current springs. I heard they also developed a new MCPCB that can sink 200W for the E21A emitters that is more expensive than copper mcpcb. FF also offers high flux bin, and good tint binned emitters; binned emitters are much harder to procure and more expensive than unbinned emitters that the typical flashlight manufacturer buys. There are other parts that are upgraded (more expensive) and sometimes a single component cost more than a cheap flashlight. FF is really going high end.
With the XP-L2 and high drain, I suspect we will be seeing 13K+ real lumens considering my Nitecore TM9K makes 9k+ lumens using a non high drain built-in battery. This will be like having the power of the Olight Marauder 2 in a compact size. This should be a good bit brighter than the two Matemino MT18S I measured.
Here are a few reason why the light will be more expensive than the E07:
-Almost twice the amount of LED’s
-Much better driver
-More mass = more metal
-Very few lights similar to this one on the market
At sub $100, its not budget by any means, but a similar light from one of the big brands like Eagtac, Fenix, Olight etc would cost well over 100$ for sure.
I think $80 would have been the sweet spot for such a light, but for the value it gives, I wouldn’t call it just an expensive flashlight.
