I think the issue is that getting a great LED bulb is so tricky that people just give up on LED and move to Halogen. Halogen is just incandescent with an efficiency enhancement. Nothing that puts it in the league of LED, but better than raw incandescent.
I choose Incandescent because I cant figure out which LED option to choose
for the most part I find LED house lighting makes for muddy colors
and I get lost reading ads, hunting for relevant specs
Im considering buying this,
90-CRI-Light-Bulb-2700k
do you know if it is going to give as good color as incandescent?
here is a
5000k 90CRI option
maybe good in a kitchen or workshop
I have not figured out how to find the duv (Tint) specs for those options
help welcome
Likely not. In my experience, CRI ratings of 90 or lower usually mean a jagged spectrum.
I thought, “Tint free” only applies to emitters on par with, or better than Nichia Optisolis 5000K/6500K (up to 4000K, they are inferior, because of fundamental differences - they have a noticeable light blue/cyan weakness (dip), which the higher CCT Optisolis don’t).
Even Luminus SST-20 and Nichia E21A at ~95-96 CRI exhibit some kind of tint.
No offense, but at only 93 CRI, I feel like I was being clickbaited
(Still, upgrading to lower 90-ish CRI still does worth from the so-called “standard” 80 CRI)
Edit: it seems, that I didn’t read all, which was written. So you apply correction painting manually. Ok, now I got it.
Tint free here means a DeltaUV (or Duv) of zero. Duv is the deviance from the Black Body Locus. It applies to all CCTs.
I was looking for good LED bulbs for years until I finally found Sunlike
Yea, Sunlike are good. And $22 per bulb.
A bargain considering the product
I felt the same about all the $20 Cree bulbs with 20-year warranties that I bought years ago. They only lasted 3-4 years, then most died. These days I feel Sunlike are better made than the Cree, but I’ve been wrong before, obviously.
These days I believe in good LEDs for the 2-dozen or so lights you run the most hours every day/night. And halogen everywhere else. It sounds like you don’t mind spending 22x6=$132 for one room. If that’s in your budget, I agree Sunlike is where you should invest.
It really isn’t possible to have a sufficient heatsink and reliable driver for less than that. I still use quite a few cheap Hyperikon bulbs but I’m replacing them as they die with Sunlike. One nice side effect of having beefy drivers is that the Sunlike bulbs don’t flicker when my car is charging which around a third of my hyperikon bulbs do.
Have a look at one of my Cree that died:
It had a huge aluminum heatsink, a 20 year warranty, and a $20 price tag to match. And it’s from my large box of matching dead bulbs. What kind of warranty do the Sunlike come with?? Does that warranty cover spectrum deterioration as the LED ages? That’s a real problem.
What does the driver look like? That’s the most likely reason for its premature death.
I agree the driver is probably to blame. But it’s under warranty, and I hope to mail a box of them in for my money back.
We just lost another Cree in the office today
I just did a count, today’s dead bulb brings the total to 20. 20 bulbs x $20 each = $400 lost. I wanted to send them in and lay claim to that 20-year warranty they had, but the receipt paper has gone blank from 5 years worth of age as it always does. I’m probably screwed.
The old Cree bulbs have a CRI of 84 and a R9 of just 17. So the new Cree should be noticeably better since they are advertised with a CRI of 90. I stared into a Hyperikon to see if I could understand what you meant by the light not being smooth, but it looks like shear perfection on my bulbs. They are as evenly lit as the sun. You must have a different model.
Old style Cree bulb:
Have they even sold those bulbs for 20 years? You can probably make an argument based on this
That’s a great point, though I doubt their verdict will be up for debate. But the counter to that could be that I found them in a dumpster and don’t qualify. Who knows. I need start that horrible process of trying.
I warrantied my Cree TW bulb, called them, they sent me a new bulb. No receipt, they just use what’s printed on the bulb, super easy.
Oh, that’s great news. From what I read on the box a few years back, in sounded like I needed to mail them to the address on the box and hope for the best. Thanks for the info
