Yes, clamp, with tailcap removed. It's not like it would be left for minutes on running at that power level, so I'm not concerned. On max/turbo, these kind of lights simply can't handle much beyond 30 secs. The light will be much hotter than the cell.
Thanks for the link. I did ask Vapcell AliExpress and they mentioned it’s out of stock, not sure when will restock.
Was hoping to grab a few during the 11.11 sale.
Also, kudos to Vapcell for now having some shipping option for batteries (there is some shipping fees, but at least there is a shipping option now to my country — whereas before, Vapcell AliExpress “does not deliver” to my country. Although I notice, some batteries in the Vapcell store will still indicate “no shipping method” to my country… I ordered some Vapcell H10 14500, hopefully the order will not get cancelled, or ask me to pay “additional” fee for shipping to my country…
Depends which K1. The K1 SBT90.2 is wayyy different from the OSRAM's. The K1 SBT90.2 will do best on a 30T for max output, but not last long. I think it's a good choice though for the SBT90.2 because of it's decent high performance and longer runtime.
For the OSRAM's, It's a good choice for sure. I would think it should keep a higher level of output longer. Won't make a difference in the first couple of minutes on a freshly charged battery, but in theory, should produce higher amps during the course of draining the cell.
So it all depends on your usage scenario, what you want, and what version K1 you have.
I think it's the best all around 21700 cell on the market today, well, if it was on the market that is...
Maybe Dennis can tell use if it's the Samsung 50T or not -- would be nice to know. The 50T isn't available anywhere also it seems.
These things of rewraps can get confusing, like made in the same factory but not Samsung branded, etc. Might be quality/rejection differences on the final product, etc.
Ohh, also depends if it's a modded K1 SBT90.2 or not. If you added spring bypasses and replaced LED wires with thicker ones, you could get over 20 amps. Probably with the stock K1 SBT90.2 it would stay under 20 amps. My modded K1 measured 24 amps on the fully charged T50, but of course that drops fairly quickly.
well i would be getting osram, so i know that should be enough, but for sbt tho, i thought 20A is also enough right? stock of course, not modded. thats why i thought this would cover all k1 emitters.
20A should be enough, yes, but 30T's are the lowest resistance cells on the planet, so you will always get max amps on them on straight FET drivers and high performance LED's like the SBT90.2. I got 19 amps on a 40T on my K1 SBT90.2 when it was stock.
The T50 really should be the best cell for the K1 OSRAM's - should produce peak amps for the driver/LED combo for the longest time.
I'd buy 6-8 more if available, just for my own use, but I'd still like to see HKJ test results. He tests a pair, so at least we'd get some feeling of consistency.
i bought some 50G for it, for osram, u think its good? cuz i saw 50E being recommended, and from what i saw in HJK test, 50G is just a slightly better version of 50E, right?
Ok so can someone clarify something for this old fart?
When ordering on the AX store, there is an option for 1 piece button top or 2 piece button top. What is the difference? Does any of these come with a protection PCB?
