Depends which K1. The K1 SBT90.2 is wayyy different from the OSRAM's. The K1 SBT90.2 will do best on a 30T for max output, but not last long. I think it's a good choice though for the SBT90.2 because of it's decent high performance and longer runtime.
For the OSRAM's, It's a good choice for sure. I would think it should keep a higher level of output longer. Won't make a difference in the first couple of minutes on a freshly charged battery, but in theory, should produce higher amps during the course of draining the cell.
So it all depends on your usage scenario, what you want, and what version K1 you have.
I think it's the best all around 21700 cell on the market today, well, if it was on the market that is...
Maybe Dennis can tell use if it's the Samsung 50T or not -- would be nice to know. The 50T isn't available anywhere also it seems.
These things of rewraps can get confusing, like made in the same factory but not Samsung branded, etc. Might be quality/rejection differences on the final product, etc.
Ohh, also depends if it's a modded K1 SBT90.2 or not. If you added spring bypasses and replaced LED wires with thicker ones, you could get over 20 amps. Probably with the stock K1 SBT90.2 it would stay under 20 amps. My modded K1 measured 24 amps on the fully charged T50, but of course that drops fairly quickly.
well i would be getting osram, so i know that should be enough, but for sbt tho, i thought 20A is also enough right? stock of course, not modded. thats why i thought this would cover all k1 emitters.
20A should be enough, yes, but 30T's are the lowest resistance cells on the planet, so you will always get max amps on them on straight FET drivers and high performance LED's like the SBT90.2. I got 19 amps on a 40T on my K1 SBT90.2 when it was stock.
The T50 really should be the best cell for the K1 OSRAM's - should produce peak amps for the driver/LED combo for the longest time.
I'd buy 6-8 more if available, just for my own use, but I'd still like to see HKJ test results. He tests a pair, so at least we'd get some feeling of consistency.
i bought some 50G for it, for osram, u think its good? cuz i saw 50E being recommended, and from what i saw in HJK test, 50G is just a slightly better version of 50E, right?
Ok so can someone clarify something for this old fart?
When ordering on the AX store, there is an option for 1 piece button top or 2 piece button top. What is the difference? Does any of these come with a protection PCB?
On 11/11, I wanted to buy some batteries and ran into trouble. When I had everything together, I saw there was shipping on each battery added to the cost, inflating the price to something not very attractive. Sorry, I haven’t read all postings in this thread so don’t know if there was a solution. Did I do anything wrong? I’d like to use the next opportunity this month, probably buying not as many batteries as I got some meanwhile elsewhere, but still a few.
You could contact Vapcell Official via AliExpress to see if they can adjust the price. They might ask you to make an order without paying. They can adjust the price of the order rather than try to adjust the listing.
To make an unpaid order, I changed the payment method for my account from debit card to Paypal. I didn’t authorize AliExpress for automatic payments via Paypal so this step is manual. When I checkout and go to pay, the app redirects me to Paypal. I go back instead of paying. And the order goes into an “Unpaid” state.
Just trying to order a big amount of batteries incl. T50. I hope customer service can help me quickly to adjust shipping costs before T50 is sold out.
BTW: What kind of buttons do you use for button top 18650 batteries? I want to order 4x Molicel P26A and 4x Samsung 30QT, all with button top. I hope these buttons will not significantly increase internal resistance. I once bought some batteries elsewhere with joint-welded buttons and these became loose too easily and were of very bad quality.
