Well, I've been expecting this to happen eventually with 21700's. Age old argument around about carrier vs straight SRK/Q8 style tube with brass ring for batt+ contact.
For drivers and LED's like this (very high amps, turbo FET), I prefer the brass ring batt+ design over a carrier because there's less transition/contact points and therefore less resistance. Also the carrier designs will be more expensive, more complicated, subject to parts that can be cheapened down. I've worked with high quality carriers but all those are in expensive lights. However the BLF GT line of lights have excellent quality carriers, made by Lumintop.
Back in the days of the Q8, it originally was difficult to find high performance 18650's with button tops. Only because we demanded it, it eventually became more commonly available, least this is what I believe from what I seen. In the days of the Q8, we had battery dealers like Liionwholsale jump on the Q8 bandwagon with special deals/discounts of button tops for the BLF Q8 community, and Banggood and Neal of course also had some great 30Q BT deals helping us.
The triple 21700's should become more common, and for 3V LED's like the SBT90.2, OSRAM's, SST-20/40's, 351D; Nichia's, etc., parallel configuration will still be around a while. Unfortunately the HK90 doesn't have the clout (number in sales) to demand this of the battery retailers for providing button tops.
Unfortunately along with high performance button top cells, came the cheap, poor methods of doing a proper button top. Some BT's have the button just sitting on the top, secured by an outer wrapper - no spot welding. Also the quality of the metal used in the BT varies greatly. BT's are very much subject to quality problems resulting in increased resistance, negating the result of high performance cells. 30Q BT's from 2 different sources can have different resistances all because of the BT - we've seen this.
I see IMR has BT's on the 30T and 40T, though for $2 more which is a big bump in cost - hope it's a quality top done right.
Yeah they never have been in the past for me. I suspect I’ll get 500 more lumens with 40T and 1000 more with 30T, stepdown was ludicrously fast now 3 cells contact, 20 secs, gonna have to program a higher temp.
I ordered the HK90 from this Group Buy September 7, and it shipped on October 14. But the tracking number yields zero information. When should I begin to ask where the flashlight is located at?
Thank you for checking on my order for me, I really do appreciate it. I really do want this light! This light has both a little bit more throw and also somewhat more power than the X65, therefore it is a must-have item. If my references are correct and if I recall correctly, both lights weigh almost the same with batteries. I anticipate a beam profile that is a little bit longer and a little bit wider and a little bit less cool white than the X65. A beam profile and performance that I gotta have. Thanks again!
I finally got my hot little hands on the much anticipated HK90, one hour ago. It is the one that I ordered from Vinh54 on October 26. Driver VNX2, spec card says 14,000 lumens and 750Kcd and 1732 meters throw. 5,700K, de-lens. it came with 3 x Vapcell INR21700 4,000 mAh, 30A, solder blob top cells.
The HK90 that I ordered from here on Sept. 7 is lost in space without a trace.
I'd be interested in what vinh did with centering the LED's after the de-lens. I thought about it, would probably give me the same throw h spec'd (about 5% bump), but the centering pieces center on the lens frames, so if you remove them, you could take your chances on centering, and not destroy the LED's by hitting the wires, or come up with another way to center them. If you could take a pic down the barrel at the LED's, much appreciated.
Hi Tom E, Please let me know what you think of the pics that I linked to. :) I need to delete them soon to conserve attachment space. Does the centering look ok after the de lens?
Oh sorry - just looked at the pics. Ok, they look well centered and appears he kept the stock centering pieces. Not sure, but maybe the centering pieces have a lip to still sit on the MCPCB. You can delete them if you like.
Actually this could be why vinh is doing only 2, and called it a "Pain in the butt light to build so I decided to only build 2. "
Thanks, Tom, for your valuable observations. More good news: The HK90 that I ordered from this group buy ten weeks ago suddenly has surfaced: its tracking number suddenly went from no information, to materialized on Earth, at a location near me. Not only that, but on its way to me, arriving soon, too!
