What did you mod today?
I see many great new mods in this thread, with lots of nice pics. Fun to read, and modding is still very much alive on BLF! :sunglasses:
My mod this morning:
Last year I bought this little cheap travel clock in a local shop, out of nostalgia because these have been around for 30 years, but also because they are nicer IMO than the digital ones.
It works on a single AA battery and has a small bulb to light the display at night. But unfortunately the display lighting only works by pressing a momentary switch on the back, letting the switch go switches the light off again.
I was sure that it was a led but behold it turned out to be a mini incan bulb. The design is really 30 years old. But I guess it is also laziness, the battery is 1.5V so you would need a little boost circuit to light a led from it, that is why they still went incan.
I really want to light the display continuously, that makes for a nice beacon on the bedside table at night and saves clicking a button if I want to know the time. Having the incan bulb on all the time would drain the battery in no time, but I reckoned that a led at sub-moonlight level, which is what you want at night, should draw small enough current to have it lighted permanently.
This is the plan: a simple Joulethief circuit using a QX5252 component (ebay), an inductor (also ebay), and a 2300K 90CRI 5mm led bought from rngwn. As can be found online, this is the circuit (pin 1 is not used, it is for adding a solar panel to have the battery charged):
The current through the led is adjusted by the value of the inductor, higher value gives smaller current. As I want less than 1mA, I needed a very high value inductor, after experimenting I found what I needed: a 10mH inductor causes 0.260mA and 0.017 lumen from the led. 0.260 mA should drain a typical alkaline battery in over half a year, that is fine :slight_smile: . That is 45 lumen/W btw, which is way better than I expected from this circuitry at such low level.
Opening up the clock revealed what was expected, some wires coming from the battery connected to the glued-in incan bulb via the switch. The bulb was easily pryed out.
The hole for the bulb was widened with a drill to fit the 5mm led. (not shown) the new hole as seen from the clock face looks quite neat btw.
The cutout in the display cover was widened too, this was not a great job as you can see but it is nice enough.
Here is the circuitry soldered in place. The switch was left out, the led runs direct from the battery.
And after closing the light it works nicely and the illumination level seems just right to me :-).
The picture makes the illumination of the face look more uneven than in reality, in fact the illumination is very nice and better than from the stock incan bulb. I measured 2260K, 94CRI and duv=0.0017. I put in a new battery and let’s see if the runtime is indeed more than 6 months :)
@Tom, in your post #9543 two lines in the posted software are very long, causing this whole page to display extremely narrow on mobile devices :frowning:
Excellent mod Jos! Very cool and practical.
Don’t I remember you modding another travel click before? EDIT: yup, here it is
It is this same one, the post that you link is about finding out that the bulb was not a led, so the mod was not as straightforward as bypassing the switch and adding a resistor. So I collected some parts and today I did the actual mod with the boost circuit.
Ahh that’s right. Thanks for jogging my memory.
Nice. :slight_smile:
What would be the current when the battery is near-empty?
Still 260 micro-amps I guess, the QX5252 is supposed to deliver a constant current and in this case I made it so low that a near-empty battery should still deliver that.
You are the only one to comment on it, and that's a syntax issue. So to the trash bin!
Just a waste of time, sorry to say - gone.
Nice mod on the clock light, btw!
That is a thorough way to solve it, of course deleting the post was not my intention :frowning:
I was thinking this the entire time I read the post! “Didn’t someone do this already? Deja vu?” I’m glad someone else remembered it as well. Great spectrum on that original :wink:
Been a while, hope everyone’s been well.
Swapped a 4000K LH351D into a JETBeam Mini-One! Much better than the XP-G3. Wasn’t too bad but the bezel is definitely glued and was a PITA to get off.
I realize this light has a glass lens that’s easily replaceable but i wanted to make a lens cap for it anyway so I lathed it up out of plastic.
No prob, I had a copy and re-created the post in a thread on the Amutorch AL1 mod here, since there's no other threads in existence for this light.
The AL1 didn't get much attention and was dropped from BG, but still listed on the manufacturers site here:
https://www.amutorch.com/products/amutorch-al1-titanium-right-angle-flashlight1100-lumens
Mod Brass AAA Tool to 219b 4000k 9080 sw40:
Mod Copper AAA Tool to 219b 3000k 9080 sw30
I figured out how to get the pills out without shredding the wires. Heat the head on my reflow hotplate for about one minute, set to 100C…
3000k from a copper light looks great!
Added some personal touches to one of Sinner’s new 18350’s. Click image or link below for gallery with a little detail.
Gallery: https://imgur.com/a/L8ijv3k
LUX-RC 371V2 with 351D?
Not bad, not bad at all sir!
I’ve always wanted to own a Sinner’s. Impressive mod, Sir.
^ What he said :+1:
I had to make a new bezel on this copper light because the focus wasn’t right. I rubbed off some of the patina with the constant handling doing the mod.
I finally got around to fitting the lume1 driver to the TiCu so it now matches the damascus :heart_eyes:
Outstanding mod!
Great video, love the new driver’s headstand auto dimming…
