I also think this is a great option. Note that if you look at spectrum, you will see a small spike in the usual place at in the blue range. I have not found any research showing that this is a concern compared to smoother spectra of the same color temperature. I’m pointing it out in case this matters to you, but I suspect a low power 3400K LED like this has pretty minimal effect on melatonin suppression.
The spectrum in this post should be for the same LED:
you Can just buy Amber leds, not the blue ones with the phosphor coating, but propper amber light direct from the Silicon itself, no blue (or other colors) at all
Are you also using tint shift on any electronic devices? I didn’t pay much thought to that kind of thing until I tried it on my computer. Instant improvement in my sleep.
In the other forum, Vinh Nguyen is offering Manker E02 II’s with various alternative LED’s. One is SST20, 3000K. That has 95 CRI and a pleasant amber-ish cast to the light. It also offers around seven light levels and runs on a AAA.
I checked the SkyLumen site and it says that the Manker E02 II is sold out. E-mail Vinh anyway and tell him what you want. He’s already had one encore batch of this choose-your-own-LED light in response to popular demand and it might be possible to get him to do a second one.
Note: I got E02 II’s from him with SST20 3000K (which is the combination you probably want) and 419b 4500K. They’re very nice and maintain the ultralow light levels that jon refers to. However, a third E02 II with a XPE-2 red LED didn’t have the low levels. Apparently there was a problem with the combination of the driver and that particular LED.
UPDATE: Vinh tells me that he’s just put them back up on his site a third time, but the number will be strictly limited. That’s because he’s charging about the same for the entire light as he normally would for replacing an LED. He’s also added 219b @ 3500K and 4000K to the options. Order while you can! Jon’s link above is to the page with the stock light. Here’s a link to the page with the pick-your-own lights: https://skylumen.com/products/manker-e02vn-ii-you-pick-led-limited-run
You can get a flashlight with ramping capability, which will allow you to use any brightness between minimum and maximum.
Most warm white flashlights emit a significant amount of blue light.
Some amber leds also emit blue light, because there are 2 kinds of amber leds:
(1) narrowband amber (single color only, led is based on an amber chip)
(2) phosphor-converted amber (all colors with peak output in the amber area of spectrum, led is based on a blue chip with phosphor on top)
You can still see colors with a phosphor-converted amber led, you cannot see colors with a narrowband amber led.
If your goal is limiting blue light, and you don’t care about seeing colors, your best bet is a flashlight with a narrowband amber led. XP-E2 Amber is a good narrowband amber led.
If your goal is limiting blue light, and you care about seeing colors, warm white E21A 2000K R9050 is a better choice than phosphor-converted amber, because it has a very low amount of blue light and great color rendering.
If use of AAA batteries is not a strict requirement, you might want to consider Emisar D4V2 or Noctigon KR4 with XP-E2 Amber emitters. They are not available as an option on https://intl-outdoor.com/, but you can order a custom flashlight with those emitters if you send Hank an email. You can find his email on his site.
Custom Emisar D4V2 with XP-E2 Amber would be bigger and slightly more expensive than Manker E02vn II , in return it would be a lot brighter (it has 4 leds, not just 1), with much longer runtime and optional magnet in the tailcap. It uses Anduril software, which is popular and has many useful features, such as ramping modes where you can customize the maximum and the minimum level, and flickering candle mode with optional timer.
I have a custom Emisar D4V2 with XP-E2 Amber that I purchased a month ago.
Manker E02vn II with XP-E2 Amber sounds like a good fit.
Emisar D4V2 with XP-E2 Amber can be a lot brighter, but you can choose the exact amount of light that you need, because it supports ramping. Minimum, maximum, or anywhere in between.
amberlight wrote:
Thanks, which one should I choose?
Do you think he would ship to the UK?
Here are some option:
XPL2 6500K
XPL2 3500K 80CRI
Nichia 219b 3500K 90CRI
Nichia 219b 4000K 90CRI
Nichia 219b 4500K 90CRI
SST20 3000K 95CRI
SST20 5000K
SST20 6500K
XPE2 Red
XPE2 Blue
XPE2 Green
XPE2 Amber
Ask him! skylumen54@gmail.com.
Keep in mind that he’s only offering 7 more of these pick-your-own-LED versions of the E02 II in this batch - and I’ve ordered one of those already.
I have a couple of the thrunite Ti3. Wonderful little light. Most are a pleasure roughly 4000k neutral white. One is much warmer. Almost a yellow, though not amber. Perfect for what you are asking, but of course it was luck of the draw. They are easy to disassemble, though so perhaps an emitter swap would work for you.
Of course the c01 would be excellent as well, though it’s actually larger.
Another though is that maybe a LRI photon freedom in amber or yellow. Very light and compact.
Hey! I have the original C01 with the Yuji emitter and it is one of my all-time favorite little flashlights. The light level is “just right” for night reading, small tasks, etc. The run-time is excellent. It’s also a great choice for kids who are too young to not shine it in people’s eyes but old enough to not try to eat it.
How does the 3400K Sophia version stack up? Also, is red version like a single-mode version of the C01R?
