WTS: Streamlight, FourSevens, Fenix, and other lights and accessories
7 posts / 0 new
Lightfan
Last seen: 2 hours 31 min ago
Here is a varied selection of budget flashlights and accessories for sale. I cleaned every light's threads with white vinegar and lightly lubed the threads with DeoxIT D100L (red).
This sale is for the US only, and all prices include first-class USPS shipping. I only use PayPal currently, so please PM me for my PayPal address. Thank you for your interest!
UPDATE: I haven't posted any items for sale in a while, so I overlooked linking the pictures to the original ones. If someone would like more/bigger pictures, please let me know. Thank you.
FourSevens QPA $23: This CW AA/14500 light is in good condition with some nicks in the anodizing at the bezel and tailcap. A sticker on the box notes the emitter is an XP-G Gen2. The light is shown with a forward clicky, but if you would prefer the reverse clicky, I will include it instead. The standard clip is installed, but I will also include a deep-carry clip. The standard accessories (holster, lanyard, FingerGrip, 2 extra O-rings, and manual) are also included in the worn box.
FourSevens Quark Smart QSL-X $23: This CW CR123A/RCR123A light is in excellent condition. I will include the holster, lanyard, and an aftermarket clip.
Fenix E01 $18: I think this discontinued and renowned AAA light is the 10-lumen version because its beam was dimmer when comparing it to one of my other E01s. It's in very good+ condition with only a couple specks of missing anodizing. I lightly sanded the LED and "reflector" with steel wool to remove artifacts from the beam.
Icon Rogue 1 $13: This CW AA light is in good condition. The plastic lens has a couple scratches, which is shown in the 2nd image. Two lanyards are included.
***Each of the following items is available for the listed price when purchased with at least one of the above items.***
ThruNite Green Ti ($6 with additional purchase): This CW AAA light is in excellent condition and is the 2-mode version with 3 and 60 lumens. The foam donut in the bezel came off, so I reattached it with epoxy.
Streamlight Stylus Pro with Green LED ($5 with additional purchase): This orange-camo version is in good condition. This is also an older model with the three-piece body and one-way clip. I did remove the head (by heating the glue) so I could install FourSevens Preon and Fenix L0D heads to increase the Streamlight's versatility, so it is also ready for the next mod project. The body has a tacky feel, but I think that is inherent of the camo pattern.
NiteCore HB02 Headband ($5 with additional purchase): This versatile headband is in excellent condition.
NiteCore D20 ($8 with additional purchase): This 2AA light was updated (by another user) with a warmer emitter, but I don't recall which one. It used to work as designed, but I noticed at some point the light wouldn't turn off when the head is fully screwed on. I don't know if this construction is normal, but I found the piston sticks out of the body (see 3rd image) when the tail's retaining ring is fully tightened, so the head must be unscrewed slightly for the light to turn off. So, I hope someone can fix it or just use it for parts. I no longer have the clip.
***SOLD***
Fenix L2D CE $24 Sold to spoonrobot: This CW 2AA light is in excellent condition. I will include an aftermarket clip along with the following 3 Fenix diffusers: AD102-W white diffuser, AD102-R diffuser (which has a crack but still works as expected), and AD401 diffuser lens (which has some black permanent marker on the sides but still works as expected).
FourSevens Atom 360 Headlamp Kit $13 Sold to jon_slider: I just never used this kit since I prefer dedicated headlamps, so the kit is in excellent condition. Included are the headband, cradle (with neodymium magnet), 3 fitted adapters, and 2 pairs of O-rings in different sizes.
Streamlight AAA Bundle $25 Sold to Renthal:  These 2 Stylus Pros and 1 MicroStream are in good condition. They are the older models with the three-piece bodies and one-way clips. I removed the heads (by heating the glue) so I could install FourSevens Preon and Fenix L0D heads to increase the Streamlights' versatility, so they are ready for the next mod project. The blue Stylus Pro has "MSI HVAC" printed on its body.
FourSevens Preon Bundle $18 Sold to Renthal: This is the Gen1 CW version. When tightened on the 2 red bodies, the head (which does work) does not make full contact, so it doesn't turn on. I did get the light to power on when putting a small piece of aluminum foil on the threads before installing the head, so it appears to be a contact issue, which I recall hearing from other users. The head does work on other lights (like the Streamlights in this sale, hint, hint wink), and it may work on other Preon bodies. The black body appears to be a later version in that the red tailcaps do not fully screw onto the body.
Thorfire TK01 ($6 with additional purchase) Sold to Renthal: This is a nice AAA twisty light and is in excellent condition. It has one mode (85 lumens) and uses a high-CRI Nichia 219C.
Edited by: Lightfan on 11/22/2020 - 22:44
jon_slider
jon_slider's picture
Last seen: 5 hours 53 min ago
> FourSevens Atom 360 Headlamp Kit $13:
I will take it, please PM me your paypal info
"High CRI Lights for Sale":https://budgetlightforum.com/node/75426
fonfan
Last seen: 10 hours 46 min ago
Quote:
I’ll take
FourSevens Preon Bundle $18:
cancelled
WANTED Zebralights. My flashlights
fonfan
Quote:
Add ThruNite Green Ti ($6 with additional purchase):
cancelled
spoonrobot
Last seen: 12 hours 11 min ago
I will take this PM incoming
Quote:
Fenix L2D CE $24
Renthal
Last seen: 4 hours 28 min ago
Ill take the streamlights, the preon and the thorfire tk01.
Lightfan
Thank you, Renthal! Please PM me for PP address.
