I got my two lights today. After a bit of futzing around I was able to adjust the panel and light/sensor for my installation, which is inside a carport. Sun comes through a sunlight to charge. I got home late in the day, so the panel didn’t get a lot of light before dark. I eventually figured out the switch is a slider (like me) not a push button, and got it turned on. I did a quick compare side by side, the light puts at least as much light as my LT1 on high. Its plenty bright in my setting. Its advertised at 800 lumens, I believe it.
I did a quick disassemble of the panel to see what sort of battery is in it. Reviews said it was not replaceable. After removing 8 small screws, I found a single 2200mAhr 18650 cell charged to about 3.8V. I measured the current draw, its 1A. The panel housing has an o’ring and a tongue and groove fitting, so I imagine it’s pretty water resistant. I didn’t disassemble the lights, just the panel housing.
If I could have bought one for $13 it would be a screaming deal. I didn’t need two, but I’m happy with the purchase and would definitely do it again. Hope it lasts as long as the one I bought 6 years ago and is still going strong, but is much dimmer.
Nb: that’s for a tupac of WW or CW, but there’s also a colored version (1-per) for 6fitty, too.
I got a few of those that take batteries, for indoors, and they’re pretty nice. Thinking of getting a solar version to put outside and not have to screw with it, just set’n’forget.
Just because, I had to measure the charge current on the solar charged security light
Charges at 0.25A, so like the manual says, even if its fully depleted a good day of sun will get you mostly charged back up again. And you would have to run it for a couple hours for it to get depleted. If the battery doesn’t go belly up, and it doesn’t leak, then this should last forever. When the cell dies, just pop in another.
Oh, I started to take one of the light housings apart, and one of the screws wouldn’t back out. So I put it back together and noticed two of the screws seem stripped. So this could be a source of the leaks that were reported in the reviews. It looks fine, and I’m guessing it will be fine, but that may be the weak point.
Thrunite TH01 headlamp (35% coupon) and the T1 as seen above (25%) are both about 30 USD right now with the clickable coupon. The Wowtac 16340 versions of these are the h01 and the W1.
The Thrunites offer more capacity (18350 vs 16340), higher output and regulation, longer runtimes with more efficient drivers and XHP50 vs XP G2 emitter, and ramping UI.
I bought a Wowtac as a gift, but for myself I like nice flat regulation so I would choose the Thrunite for myself. You get what you pay for here and I think either the Wowtac or the Thrunite are decent kits for the price.
This was fairly easy to assembly, seems all metal (except maybe the flexible part) and is very intuitive. I figured out how to turn on, up, down, change the color, in about 15 seconds without the manual. Nice light.
