Vapcell INR16650 2000mAh M20 (Gold) 2020
Official specifications:
Typical Capacity: 2000mAh
Min capacity: 1950mAh
Nominal Voltage: 3.6V
Charging Voltage: 4.20+โ0.05V
Discharge End Voltage: 2.5V
Max. Continuous Discharging Current: 8A
Dimensions: 65.0mm (L) x 16.5 mm (D)
Max Weight: 38g
Vapcell LiIon batteries in 16650 size.
The batteries tracks nicely, but voltage and capacity drops a at higher current.
Conclusion
Usually 16650/17650 cells are based on a 4.35V Sanyo cells, but not these cells and they can deliver considerable more current.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
