Perhaps opportunistic, but do AliExpress coupons stack with discounts that Simon may give? I’ve got a project I’m working on, and am trying to do it in the most cost efficient way I can.
You must see WebMoney, choosing WebMoney works. Choosing PayPal should also work no problem. Just dismiss the payment page in any case.
Alternatively, you can use AliExpress application 8.4.0 or earlier. With it you can select “other payment methods”, the archetypical way. The app checks for updates just on startup, it counts the number of times it asks you to update and after a number of refusals it ends up forcing you to update (or clear }) application data). This is solved by launching the app while on airplane mode, while it shows the launching advertisement. As I've found many times, old versions of software can be better.
Can somebody help me please? I had M21B with SST40 for some time then bought S21B with CULPM1.TG and decided to switch leds - install SST40 into S21B and CULPM1.TG into M21B. I have replaced leds, but faced a problem with gaskets - the one from S21B is too small for SST40 and the one from M21B is too big for CULPM1.TG. What gasket should I order for SST40 in S21B and for CULPM1.TG in M21B?
Unless you are using it with single mode, or
unless you mod the driver with a resistor, or
unless the new drivers are prepared to be used with a lighted tailcap…
I would say “no”, because it will jam the modes order (wether you have memory configured or not).
Using Biscotti with lighted tailcaps will make it jump when you turn OFF/turn ON the light. Specially if you are used to always start in the lowest/highest modes of the sequence. If you don’t care about it turning ON in a random mode, go for it
I am glad, that not only me, but other people are saying this. (I already made here a warning few weeks before, as I had experience with a build including this emitter.)
For small bodies like S2+, 4×7135 should be the best (I’d go with the 5-30-100% plain old but good driver).
For a Convoy C8+, I think, 6×7135 would be a sweet spot, maybe 8×7135, if somebody goes for the safe maximum output.
