I kind of explained the reason a few post above. I have two MF01S and I never use them because of the size and because it does not have a regulated driver. The 7135 and FET drivers on the Astrolux, Lumintop, Hakelite, Nightwatch have the same problem. Very inefficient and output drops quickly to impractical levels.
My E07’s have had great quality, no complaints there. This E12 has more LEDs, built-in charging and a better driver. Plus, I’m sure there’ll be coupons or group deals coming out soon which’ll reduce the price.
The truly overpriced flashlights are those ‘custom’ titanium ones that have like 600 lms and cost $400.
Not baiting you but I would be interested in which competing lights you mean? As I can’t think of anything close for size/output/tint - and IMO coke can size lights don’t count as we are talking one battery here.
The only thing similar is that FT02s should produce similar lumens under initial turbo output but is only available in CW 70CRI and reflector so the typical Cree ugly egg yolk or tint shift will be very noticeable. The E12R uses TIR optics and will have 95+ CRI options and WW/NW (though still to be listed). The FT02S uses the typical cheap FET with poor efficiency whereas the E12R uses a regulated and high efficiency Lume1 driver. The E12R will be more of a tool whereas the FT02s is more of a toy. Astrolux does not use high quality components whereas FF is willing to invest in premium parts.
Is this for certain? I’m looking, but I don’t see a statement from either Jackie or Loneoceans about it being a Lume1 variant. Just the first post stating it will be a buck driver.
That is awesome if true.
Hopefully it would be upgraded with reverse polarity protection.
The FT02s tube is also 28.3% fatter. But regardless, you are comparing the linear dimensions not the volume. For example a 20% increase in the radius of a sphere equates to 73% increase in the volume. Even if the 2D dimensions don’t seem that much bigger, they are much bigger when you see and hold them in person. The size increase of the FT02s vs the E12R puts it in another size class. The E12R will still manage to fit in many pockets but the FT02s will require very large pockets.
I don’t know the details besides it is a Loneocean driver. Jack said he wants to really up the level of his new lights and decided to go with the much more expensive driver among other improvements despite losing price competitiveness with the budget brands.
Arguing the size is pointless as it is subjective. Some people feel the D18 is pocketable while some feel a D4 is at the limit for being EDC. If you feel they are the same size class, then you are entitled to your own opinion.
The weight of the FT02s would help theoretically but due to the budget non-regulated driver, it will not be able to make use of the mass and sustain output very well. Even my MT09R weighing 650g gradually drops down to about 200 lumens in like 10 minutes. That’s the problem with these budget lights using budget drivers. The Olight and Fenix with their efficient regulated driver can sustain output far better than the budget brands despite turbo is being much less than the budget brands. The E12R with the Lume driver should be able to sustain output better than the FT02S despite the smaller mass.
Wouldn’t it have made more sense to go with a 6v boost driver? The MS03 is fully regulated and costs less than the XPL-2 E12R. I’m thinking maybe I should get that instead.
True but I’m still surprised it costs more than the MS03. I can get the MS03 for $110.45 so $17.55 cheaper. I guess I’ll just wait for a compact 4x XHP50.2 light.
But why can’t it cost more than the MS03? More emitters, a driver design that’s less prone to fail, way better tint and auxiliary LEDs.
Immalent lights are not particularly well built and “MS03 flashlight problems” is the second most searched keyword for it. Peak lumens are meaningless when compared on paper, a 5,000lm thrower can look brighter than a 13,000lm flooder.
That is with CW SST-20 or Osram and may be slightly overrated too. Also, ROT66 has 3 batteries and 15 degree optic vs 1 battery (albeit higher drain, still not as good as 3x18650) and 30 degree optic.
Again, this light is not a thrower regardless of LED choice.
