I tried various grades of sanding on one, and the beam really improves but think I loose a lot of light. I should have measured the output before/after so I can not be sure, but compared to my second red C01 it has 30% less output
That’s to be expected. Are you sure that it is really the total output and not just only throw? And lower output doesn’t sound bad for a red light that is intended to be used in low light conditions.
how about potting the whole “cone” where the led is with clear acrylic, kinda turns the whole thing into a big TIR lens and shouldn`t lose any light, if it remains the same (and it shouldn`t be) doing scotch tape over the front would now be possible.
Potting the front with clear acrylic will remove the lens function of the front curvature of the 5mm led, it will turn the light in a sort of mule, but with a weird reflector effect. Could be a nice beam by chance though.
I measured both red C01’s properly, and it is worse: the untreated one I measure 0.45 lumen, the one that I sanded the reflector and led of I measure 0.21 lumen. But it is not guaranteed that before the sanding operation both lights had the same output so it is kind of a bad experiment :person_facepalming:
About measurement cross-checks: this is about the worst way thinkable to check light measurement contraptions. First we do not have an idea how much variation there is between output of different red C01’s, could be a lot. Second, the region of the spectrum that I found luxmeters to have the highest errors is in far red, usually they read multiple times too high in far red (as also seems the case with your luxmeter), even if the performance over the middle part of the spectrum is very reasonable.
No. I have seen the spectral sensitivity curve of my luxmeter (a Mobilux class A meter) and it is extremely accurate even at the flanks of the visible spectrum. So I can use the same conversion factor for all sources of visible light.
I may be showing my ignorance here, but why would the driver be different? I see the driver having two functions: Boost or buck the source voltage to the correct voltage for the LED, and, in the case of a multi-mode light, make the appropriate supply changes to the LED for the mode selected.
Does the 670nm led have a different forward voltage than the others?
It does have a significant different forward voltage, under 2V, while white leds are over 3V. But still I expect the same driver, but maybe the resistor limiting the current has a different value.
Swapping the red led however requires removing the potting, I read that it is possible but personally I have not attempted that.
Did the same mod djozz did, 32K-EX and bridging the resistor (accidentally removed it ). This is really bright. Lots of pleasant light from a 5mm LED. Highly recommend.
