My question is, ‘Can a lighted switch be hooked up to this driver ? It will need power, I do not know where or the voltage to hook the leds too.’
This is for the 2020 BLF O-L contest build, so any help is awesome
You can answer here if you wish … #47… CNCman's entry to the 8th annual BLF/O-L contest [ Handmade - FINISHED - ]
This question is like asking if I can add a horn to this specific model car. It doesn’t matter the year, make or model. It can be done. You just need some DC power.
You can tap a power wire into the middle of the driver where the red led wire is soldered. That’s battery power before the main led.
It looks like your switch has an on board location for a resistor. That’s good. It should use the same ground wire as the switch circuit.
So you’ll just need to add the one extra wire and resistor. Probably a 15k to 50k resistor. All very easy.
You can see how I added a switch led wire to my L6 here. I had to add an inline resistor, though.
It will draw power whenever the tail switch is on, but I don’t think that is a problem for you.
As far as the colored leds are concerned, the resistor will drop the voltage way down to within their normal range. Without a resistor it would blow right away.
There are many different smd leds with all types of specs. Specs even change within the same model, but different color. This is why you need to experiment with resistor values. Start around 15k-30k. See what the brightness is. I think I’ve even had to go up to 100k on one of my lights due to the color and it’s high current draw.
If it were a 3 volt source I’d say start between 7k and 15k. With 6v you basically double the resistance, hence 15k to 30k.
Here is the info from MTN Electronics.
So your saying I should start with the 36K since using 2S and stack more to lower brightness ?
It comes with 2 leds installed.
Connection Points / Bridge Points:
Because this switch was designed to be as versatile as possible, there are several different connection points and possible configurations.
Switch Connections: SW+ & SW- GND (SW- is ground).
LED Connections:
If connecting directly to Batt+ or from an MCU output: LED+ & bridge “LED- GND BRIDG.”
If switching from a negative side (such as a MOSFET): LED- & LED+. Do not bridge anything.
LED Option:
Optionally, you may have two color or white LEDs pre-installed on the switch, which are often used as indicator lights.
Three SMD 0603 resistors will come included, but not installed (4.7K, 19.1K & 36K). You can try different resistor combinations depending on your input voltage and desired LED brightness. We recommend that you start with 36K—-you can then swap or stack more resistors to increase the current from there. It is not recommended to go above a few mA of current to these small LEDs. The lower the total resistance value, the brighter the LEDs will be.
OK , I see, your L6 is a S2 configuration.
Thank You very much JasonWW
The switches will come in Monday and I will experiment at that time
And I’m sorry for not understanding your earlier post, Grand kids are here distracting me
And start with the 19K resistor first.
Stacking resistors reduces resistance and makes it brighter. Higher resistance makes it dimmer.
To go above 36k you need to add another resistor in series. Sometimes you can stack them like this /\ to squeeze 2 resistors on a single pad. The proper way is to swap to a higher resistance resistor.
36k should be fine, it might be brighter than you want, but should work. If you want to dim it you can order some more resistors from ebay. I see MTNE sells a 69k resistor. If you haven’t ordered the switch yet you can have him add some of those. Otherwise, you can order an assortment on ebay. Shipping may take a while, but they are cheap. It’s handy to have an assortment on hand. You can also order an assortment of smd leds as well. It’s fun to mix and match colors.
Thank you very much Jason for explaining that so clearly for me.
I wanted to order some in the past, but its confusing what size and resistance range to order.
I will try again.
If you wanted, that driver could likely be flashed with Anduril, in which case you could probably get one of pins 5/6/7 for the switch LED (likely one controls the FET and the others are unused). But that would take a bit of doing…
Yep you are correct. :+1:
I looked at the reason and he said the parasitic drain was bad on this driver and a momentary switch used with batteries left in the light would drain the batteries quickly. I thought it will work, and the tail cap switch should control the parasitic drain. The reason for trying to get the lighted momentary switch hooked up, is to know the light is powered up. When not in use, just make sure the momentary switch light is off by clicking off at the tail cap. I may have overlooked something here because electronics are still a very weak area for me, so let me know. :question:
I wanted to use the LDO 20mm driver at first, but they were out of stock.
I do have a backup driver that uses just the tail cap switch if needed. https://asflashlights.com/-diy-parts/75-10-amp-capable-17mm-led-driver.html
im selling something i bought on amazon in a second hand market, the buyer is asking for the gift receipt. is there anything i should be concerned about? like is there anything they can do with the gift receipt that can be linked back to me in a negative way?
You may get some thicker PCB and file them down to the desired thickness.
It’s a bit painful with copper, so for people who have them I’d recommend some Virence / Led4Power alu PCBs. These are hard to get nowadays though…
As far as I know, about the best they can do is attempt to return it to amazon for the original purchase price.
That said - in the secondhand market, if people want weird things, I usually just consider that it’s either too much trouble, they’re up to something, or both. Hopefully for you it’s an option to just move on to a less suspicious buyer.
Appreciate you trying to help. I have three in total: the S2 UV, an S2+ with 7135*8 driver and T6-4C XML2, and an S2+ with (if memory serves) a 7135*6 driver and a U2-1A XML2.
