unscrewing only works with anodised lights
copper, titanium, brass wont break contact by unscrewing a half turn
however, parasitic drain is not a big drain… some lights can go for years before they kill a battery inside
imo people tend to think all parasitic drain is bad, but if it takes more than a year to kill a battery, I dont think it matters much.
I have many lights with electronic switches. They all work fine. I dont unscrew them. If I really dont plan to use a light for more than I year, I dont store it with a battery inside.
I suggest to people concerned about parasitic drain, that they take the time to learn how large the drain is, and how long it would take to drain a battery.
If you quantify the drain, you may learn it is insignificant. Zebra for example, tells us the parasitic drain on their lights is less than the self discharge rate of the battery. Nothing to worry about.
I googled Sofirn SC31 Pro parasitic drain and found this
you may need to spend some quality googling the others
another term for parasitic drain is standby drain
once we know the drain, we can learn to calculate how long it would take to drain the size battery in the light
maybe someone here can help confirm the calculation needed… to determine how long the battery would last, at parasitic drain rate…
I think it goes like this… battery is 3000mAh, divide by drain of 0.23mA (info from the video caption) =13,043 hours, divide by 24 hours = 543 days, div by 30 = 18 months…
iow, if you recharge the battery in your SC31 at least once a year… the parasites wont hurt you.
you can see from the video, that some people also know how to actually measure the drain themselves (Im not one of them)
I hope this helps point you in the right direction
Thanks, I think that is a good example of why it is such a problem.
Lots of batteries are well under 3000mAh. Even 18650’s…. And of course that would be the assumption that it is fully charged when you put the torch away.
I suspect the reality is, lots of people might have a part used battery, say 3.9 or 4.0v (resting). If you leave it for 6 months…… even on a high displacement battery, it’ll mean it is mostly no good unless you go and recharge it. As it will be mostly flat by this time.
If it is something like a 14500/16340 then with only 500-700mAh you may well have ruined that battery.
still, you asked a good question, and its always good to seek confirmation regarding specific lights
for example, I got rid of a Folomov C01 because every time I tried to use it, it was dead. From sitting on my nightstand for a week or two at a time (because I use so many other lights)
and as mentioned above, the AA Tool definitely has a problem on 14500… but not on AA
My most used lights are Jetbeam Rotaries… it took some time to locate parasitic drain info… it ended up being slightly less than 0.03mA and that light can use a 700mAh 16340…
the math says it would drain the battery in 700 div by 0.03 = 2.7 years
thats a long time…
I dont recommend storing a light for half a year, with batteries inside, but it wont ruin a protected battery. It is just unrealistic to expect a light that has been ignored for many months, to hold a charge indefinitely.
It would be better to store the batteries outside the light, imo… and they should still be freshly charged when put back in service…
and, it is always prudent to have spare batteries, and a backup light
It would have been interesting if the supply voltage in that video had also been reduced to test at below ~2.8 VDC where Anduril's built-in low voltage protection is supposed to activate as I am curious if the parasitic drain would have stopped, decreased or remained the same.
My concern was whether the low voltage protection provided at ~2.8 VDC by Anduril for the micro processors Anduril operates on would eliminate all parasitic drain on the battery so that the battery can never be discharged below a safe level and if the voltage supply in the video had been reduced to test at below ~2.8 VDC the answer to my concern would have been answered.
My guess is that once Anduril's low voltage protection is activated at ~2.8 VDC that the micro processor will no longer allow power to be provided to the main or aux LEDs (including the switch LEDs) but that the micro processor will still have a parasitic drain on the battery in order to determine when the battery's voltage is above the low voltage cutout or else how would the micro processor be able to differentiate between a freshly charged and low voltage battery and it would be this parasitic drain that would continue to discharge the battery to an unsafe voltage even with Anduril's low voltage protection activated.
Power to the micro processor is probably more a function of the physical hardware than of the Anduril software but I do not know how the various processors used with Anduril operate. It may be possible that the micro processors used for Anduril contain some built-in electronic circuitry that will not pass any power below a certain voltage.
I believe that is correct
my understanding is that Low Voltage Protection is like a switch, that shuts off power from the battery, for all parts of the light, both head and tail.
this built in LVP is what allows Anduril to work with UnProtected batteries safely, by preventing overdischarge below 2.8v
I believe this LVP is also the reason there are no Anduril lights that run on AA batteries, whose voltage of 1.5v is too low to operate, given the LVP shutoff at 2.8v.
(Until someone feels it is profitable to design a circuit that can recognize the difference between a dying LiIon and a fully charged AA. This imo is why there is no AA/14500 Sofirn with Anduril… even though it was discussed for a long time)
How did you do this, if I might ask? Any special tools (no pun intended) required? I'm on the fence as to whether or not I want to disable the LED's in my Tool's. As I use one of them as a "nightstand" light, for now I just back off the tail cap in the morning, and crank it down at night.
No harm storing lights with batteries in as a rule…… that is how they are backup lights
But backup lights that drain the batteries are by definition flippin useless
Given the choice, I’d much rather not have an electronic switch. There really seems few use cases to say they are truly better. The ramping is ok, but I’d still like a physical switch to turn it on and off. Then it simply is a non issue. Rather than fishing around looking for workarounds to solve a problem that doesn’t need to exist.
BTW - I hardly ever use protected batteries. Nearly all of mine are IMR’s…
Thanks for the link! I keep a second Tool 2.0 in my work vehicle that’s fitted with the mag tail cap to attach to the insides of metal cabinet machines I work on. I run NiMH in that one as I don’t need the extra juice or lumens the 14500 provides, but at home or out and about after dark I’m diggin’ the extra output and the rear clicky.
Lights with magnetic switches usually have a higher parasitic drain. A DV-S9 with magslider will drain a fully-charged 26650 in something like 3wks.
Then again, even (ironically) protected cells have a circuit that sniffs the voltage across the cell, and that’s parasitic drain. Granted, it’ll take a year or more, but they do drain the cell they’re mounted on, even if it’s sitting in a box and not a flashlight.
