The There Are No Stupid Questions Thread
What are the best resources on building a Convoy? I’ve seen a couple videos.
Can I build a Convoy S21B quad, which requires a 20 mm MCPCB and 22 mm driver?
What would be a good driver, board, and optic?
What sizes of LED would such an optic limit me to?
Lumileds Luxeon are reportedly very efficient. Opinions on this brand?
Yep you are correct. :+1:
I looked at the reason and he said the parasitic drain was bad on this driver and a momentary switch used with batteries left in the light would drain the batteries quickly. I thought it will work, and the tail cap switch should control the parasitic drain. The reason for trying to get the lighted momentary switch hooked up, is to know the light is powered up. When not in use, just make sure the momentary switch light is off by clicking off at the tail cap. I may have overlooked something here because electronics are still a very weak area for me, so let me know. :question:
I wanted to use the LDO 20mm driver at first, but they were out of stock.
I do have a backup driver that uses just the tail cap switch if needed.
https://asflashlights.com/-diy-parts/75-10-amp-capable-17mm-led-driver.html
Is swapping the LEDs of a Convoy S2 UV and an S2+ with a more powerful driver a bad idea?
The UV leds can’t take much power so don’t mess with those.
What led does the S2 have?
im selling something i bought on amazon in a second hand market, the buyer is asking for the gift receipt. is there anything i should be concerned about? like is there anything they can do with the gift receipt that can be linked back to me in a negative way?
You may get some thicker PCB and file them down to the desired thickness.
It’s a bit painful with copper, so for people who have them I’d recommend some Virence / Led4Power alu PCBs. These are hard to get nowadays though…
It never produced much heat so I figured it wasn’t being worked hard.
According to the description on Banggood:
  • LG UV365nm LED 5W lamp beads are used.
  • The built-in drive is 7135x5 single file.
As far as I know, about the best they can do is attempt to return it to amazon for the original purchase price.
That said - in the secondhand market, if people want weird things, I usually just consider that it’s either too much trouble, they’re up to something, or both. Hopefully for you it’s an option to just move on to a less suspicious buyer.
Sorry, I thought you were saying you had two different lights.
Appreciate you trying to help. I have three in total: the S2 UV, an S2+ with 7135*8 driver and T6-4C XML2, and an S2+ with (if memory serves) a 7135*6 driver and a U2-1A XML2.
Xml2 leds can handle up to about 8A. So you can swap the driver on them for sure.
The UV leds are not robust at all. They can not handle high amperage. So I would not swap their driver.
Maybe somebody that knows what specific LED is used can give us some numbers as to how much power it can handle. My guess is no more than 2A.
I’m not sure on the current handling, but if you search around BLF some you’ll find that all the UV LEDs can’t handle much heat, either. Even treated nicely they don’t have great runtime ratings. You can probably run them at 3A briefly and get lots of power - but, at least for all the examples I’ve looked at, you’re also going to need a 2 cells+buck driver or one cell and a boost driver to hit much current on them - the forward voltage starts high and ascends rapidly.
Wouls someone please tell me how to post an animated gif for one’s avater? Doh
I’m going to guess that you first need an animated gif that is no larger than 85 by 85 pixels. Then try to upload it in your account settings.
Yes, and your avatar must also be under 30 kilobytes.
Thanks to Jason and Scallywag for their input on UV LEDs (I left it as is).
I just recieved an Emisar D4v2 with 3500k E21A emitters, I was wondering if it’s “normal” for them to immediately turn blue on turbo with a high drain battery?
I’m assuming that it has the Noctigon driver which delivers 5A on turbo.
No, that is definitely not normal. I wonder if your driver wasn’t correctly flashed with the NoFET firmware.
The LEDs are already burned, I think I’ll send them an email.
Battery question.
Some of my 14500 batteries have a “pronounced” pip at the positive end and some don’t. I know the trick of using a small round magnet to make the pip longer. Is there something different about these batteries internal make-up? Is there any reason that thay are not all made to a standard length?
Thanks
Usually there's
flat top
button top non protected
and then button top protected
I'd suggest a solder blob over a magnet any day .
the thought of a possible loose magnet in a light gives me chills .
you can do a decent solder blob in exactly 6 seconds ...Solves a myriad of length issues ..makes life enjoyable again .:)
