well to me, it came down to 3 things, 1. it wasnt free with $6 shipping before, 2. the length, 3. the knurling, pure aesthetics, i prefer the E3A knurling design
The C01s is very nice, but for me is slightly too long for a key chain light. Around 60 mm seems to be my limit. Also since they changed the knurling, now can be a bit too smooth for easy keychain single handed usage. (wish I could get a few more with the original milling). I purchased a number of second generation orange ones for emergency usage, hiking back pack, auto and tackle box and they work great for those purposes.
I have used the i3E EOS for a few years as a keychain light and the Luxeon with the PIMMA TIR has a nice tint and color temp with the right balance of throw and dispersion for a key light. The only down side for me is the smooth indents on the head. I use a small o-ring for grip.
I would be very interested to check out the Skilhunt E3A, it looks very similar in form to the i3E but with a LH351b. The spiral knurling with the parallel secondary cut looks promising. Also may be slightly smaller that the i3E.
Skilhunt E3A and Olight i3E are
both Low CRI, single mode 100 lumens
the C01S has Two Modes 3 and 100 lumens, and the LED is High CRI…
it is no contest, C01S is the winner on spectrum quality!
the Thrunite Ti3 has Three Modes, 0.04, 16, 100 lumens, and starts on a ridiculously useless lowest mode first. Every single time I use the light I have to at least double twist… not fun. And it is Low CRI, to me, thats a Fail!
C01S wins on spectrum quality
E3a and i3s win smallest size
Ti3 wins most complex
i mean its not that hard to google when you already know the brand and model name, and you took the time to find it on BG, but you couldnt find their own website or AE?
The highCRI E3A is already out or will be out shortly.
The “regular” E3A is still hella good.
I got a key blank for my front door that shines a 0-CRI monochrome red beam, one of these:
which is all I need to poke a key into a hole.
So hang on, before anyone turns into a CRIbaby (ha! I always wanted to use that term…), just think, “What will I be using the light for?”.
If it’s to be your one and only EDC light, nothing else available, then sure, go crazy, make it a high-CRI LED with 8 brightness levels and stoopit-high R9 values to make sure you can distinguish all possible subtle shades of red.
But if you just need A Light to find what rolled under the couch, or to find the keyhole and make sure your key is teeth-up instead of teeth-down, or to find the fusebox when your lights go out, even a 1-mode Angry Blue™ AAA light should be sufficient. And especially with a twisty, being able to just flick it on once for decent light (quality and quantity) seems to fit the bill.
But then, if you need something brighter, or with more modes, and high-CRI, with sublumen firefly levels to not ruin your night-vision, I’m sure a bevy of 14500 or 18650 lights will be better, especially if you’ll be running the light for more than a few seconds at a time.
I’m hard-pressed to think how, especially considering the limited runtime of AAAs, someone would “need” a do-everything light with a super-high quality beam in an AAA format.
That’s one reason I always sneered at AAA lights, “better’n nothing… barely”, with limited runtime and limited output. From 1lm to 1000lm, great, 7 levels should scratch all those itches. But when output is limited to, say, 100lm? Even low/high might be pushing it.
But now with some nice AAA lights out there, I’m a slow convert. And like the E3A with its pebbled TIR lens smoothing even a typische Cree’s beam into something nice with no rings or fried eggs, and incredible build quality for ~10bux, I’m converted. Even the Wubens and Wowtacs and Glarees and Oilights and Thrunites… they all got their pluses and minuses. But I gotta say, I was blown away by the E3A (and the only Skilhunts I have are a few E3As and a M200).
With the ’351 or ’219 or whatever the new E3A has in it? It’d be to me pretty much the San Graal of AAA lights.
Thank you to everyone for all of your suggestions and advice. My wife is going to get me the C01S. That being said I will probably pick up the high-CRI E3A off Aliexpress in the relatively near future. It was definitely a very tough call between the C01S and the E3A.
I always appreciate how folks at BLF are so helpful. I’ve asked other stuff before as well and every time everyone is cool. Not something you find on most forums.
